Old 02-15-2008, 10:34 AM   #21 (permalink)
Originally Posted by dstepper View Post
Depends on the design. They can be a problem adjusting or taking the wheel off with disk brakes.
That's probably a result of poor frame design. I've been using slotted dropouts with disc brakes on my Surly 1x1, Azonic Evolution, and Black Market Riot. I've never had any fuss with the caliper when removing or adjusting the rear wheel. And even when I change gears on the 1x1, the movement is negligible relative to caliper position, so I've never moved the caliper. Apparently, I've been bless with frames of good design, relating to the rear wheel and disc brake caliper interface.
Devoid169 (02-15-2008), mtnbikerfred (02-15-2008)
Old 02-15-2008, 10:38 AM   #22 (permalink)
on a routine expedition
Marshall Willanholly's Avatar
Not disagreeing with you, I have EBB problems. I just don’t like the looks of sliders….love the clean look of the EBB. If I ever replace my One-9 it will be a ti frame split shell bike.
Not all sliders are created equal. I think these are very clean looking and don't disrupt the lines of the rear stays.
DeeZee (02-15-2008), Devoid169 (02-15-2008), HUGH (02-15-2008), mtnbikerfred (02-15-2008), Pho'dUp (02-15-2008), Winston (02-15-2008)
Old 02-15-2008, 10:41 AM   #23 (permalink)
Donny
Devoid169's Avatar
I agree with Marshall - the Black Cats are gorgeous and functional....but also pricey I imagine. SS manufacturers TAKE NOTE!!
God made man, but he used the monkey to do it. DEVO
Devoid169 is offline
Marshall Willanholly (02-15-2008)
Old 02-15-2008, 10:43 AM   #24 (permalink)
Default ...
I was removing and reinstalling wheels on my Sting-Ray as early as 7 or 8 (I repainted it when I was about 9 or 10), and I didn't have a problem - and I had to work with a coaster brake arm. How are slotted dropouts a challenge?
Disk brakes is the issue
The first time I saw those
Very nice looking
Old 02-15-2008, 10:55 AM   #25 (permalink)
See my post above about disc brakes.
Damn it, Marshall! Almost every time you or Carla post pictures of your bikes, I make an embarassing mess. And I'm at work, damn it! Be right back.
Marshall Willanholly (02-15-2008), mtnbikerfred (02-15-2008)
Old 02-15-2008, 10:56 AM   #26 (permalink)
On my 5th SS frame and finally have one that does not require constant chain adjustment.
Some riders do not have problems with EBB’s but I am a heavier rider and mash. After every ride (over 15 miles) I would have to adjust the chain.
This slider design has set screws that keep the sliders from moving. Once I got it dialed in the chain tension has remained the same.
That’s my story and I am sticking to it
These are the coolest dropouts I've seen so far.
Paragons are ugly in my opinion
Rivet is offline
Old 02-15-2008, 10:59 AM   #27 (permalink)
Default Got it
The Surly KM is one of the frames that have a rep with disk brake issues.
ps. That Black Cat is yummy
so are tooth brushes but they work
Old 02-15-2008, 11:04 AM   #28 (permalink)
I guess Surly doesn't always do it right. Or maybe it's how you have the caliper adjusted on the frame - there is a wide range of adjustment, and as a result, you may have your caliper in a location that makes it difficult. Also, could it be a caliper design issue? What brakes are you using? I'm using Hayes Mags.
Old 02-15-2008, 11:05 AM   #29 (permalink)
Mashers Only !!
HUGH's Avatar
I NEED a link to the maker of this frame!!!
MOTHER Fer... FRICK I am sooooo pissed right now!! Now I have to explain to Veronica why I NEED another bicycle......
HUGH
HUGH is offline
Old 02-15-2008, 11:25 AM   #30 (permalink)
On the edge of chaos
Abui's Avatar
If you saw off the derailleur hanger.
Abui is offline
Old 02-15-2008, 12:04 PM   #31 (permalink)
HUGH
He just has a blog at the moment:
http://www.blackcatbicycles.com
Not as much as you might think. Certainly less than Willits, Sycip, Soulcraft, and some others I looked at.
Old 02-15-2008, 12:09 PM   #32 (permalink)
Default Ok
I will bite......what is the price range?
Old 02-15-2008, 12:15 PM   #33 (permalink)
Mashers Only !!
HUGH's Avatar
If you have to ask......
HUGH is offline
DeeZee (02-15-2008), mtnbikerfred (02-15-2008)
Old 02-15-2008, 12:21 PM   #34 (permalink)
Default Don't
I know
Old 02-15-2008, 12:27 PM   #35 (permalink)
Ghetto Swan Lake
I think On-One has got a good slot design with it's brake mounts rotated. Easy to get the wheel on or off, but you would still need to re-adjust the brake caliper if you change gears/chain length.
Stretch yourself before you wreck youself.
Pho'dUp is online now
Old 02-15-2008, 12:57 PM   #36 (permalink)
trail-male for hire...
mtnbikerfred's Avatar
Yeah, and just how often are you going to change the gearing on your SS?
The Roger has a great design too.
mtnbikerfred is offline
Old 02-15-2008, 01:28 PM   #37 (permalink)
Abui's Avatar
Hmmm, how do you move the wheel forward to loosen the chain? (Loosen the brakes?)
Abui is offline
Old 02-15-2008, 01:52 PM   #38 (permalink)
fortytwo's Avatar
OK. Well now that it's official, I have ordered a Dean Colonel X-Lite with sliders.
fortytwo is offline
DeeZee (02-15-2008), Pho'dUp (02-15-2008)
Old 02-15-2008, 02:15 PM   #39 (permalink)
I'd rather be climbing...
KonaDupee's Avatar
Love the sliding rear drop outs on my Kona Unit 2-9er. In the 4 months that I've had it, they've needed adjusting once. That took all of 2 minutes. That bike has been maintenance free!!!!
Climbing *is* its own reward!
It's obvious I'm not a weight-weenie; I ride a Kona!
KonaDupee is offline
