Old 02-14-2008, 06:08 AM   #1 (permalink)
lkn2ryd's Avatar
Default chain and cassette question
How long should a road bike Dura-Ace chain and D-Ace cassette last? Miles?
Member of the ELITE (yet lazy) Nimrod Racing Team...
If you can read this You are definitely not FIRST! (Desired slogan on the back of my jersey.)
lkn2ryd is offline
Old 02-14-2008, 11:27 AM   #2 (permalink)
Rob's Avatar
http://sheldonbrown.com/chains.html
Measuring Chain Wear
The standard way to measure chain wear is with a ruler or steel tape measure. This can be done without removing the chain from the bicycle. The normal technique is to measure a one-foot length, placing an inch mark of the ruler exactly in the middle of one rivet, then looking at the corresponding rivet 12 complete links away. On a new, unworn chain, this rivet will also line up exactly with an inch mark. With a worn chain, the rivet will be past the inch mark. This gives a direct measurement of the wear to the chain, and an indirect measurement of the wear to the sprockets:
  • If the rivet is less than 1/16" past the mark, all is well.
  • If the rivet is 1/16" past the mark, you should replace the chain, but the sprockets are probably undamaged.
  • If the rivet is 1/8" past the mark, you have left it too long, and the sprockets (at least the favorite ones) will be too badly worn. If you replace a chain at the 1/8" point, without replacing the sprockets, it may run OK and not skip, but the worn sprockets will cause the new chain to wear much faster than it should, until it catches up with the wear state of the sprockets.
  • If the rivet is past the 1/8" mark, a new chain will almost certainly skip on the worn sprockets, especially the smaller ones.
I'd say change it at least every 500 miles, on a MTB. On a road bike I'm sure you could go over 1,000 but I would measure it every so often.
The more you replace the chain, the less you'll have to replace the cassette/chainrings.
Rob is offline
Jslow (02-14-2008), lkn2ryd (02-15-2008)
Old 02-14-2008, 11:30 AM   #3 (permalink)
Originally Posted by Rob View Post
Man that guy left a legacy. Every time I see that name in a link it reminds me what a tremendous contribution he has made and what a giant hole he left behind.
My Blog
bighit8 (02-14-2008), lkn2ryd (02-15-2008), Rob (02-14-2008), Winger (02-14-2008)
cassette and chain help!! lukewiens The Workshop 17 08-09-2008 10:00 AM
cassette, hayes brakes, chain, rotors, lock roadkillross The Market Place 16 04-17-2008 07:02 PM
Bad Link in SRAM 971 Chain ghixon The Workshop 12 12-09-2007 02:34 PM
Chain slipping on just one cog... jasonmason The Workshop 17 10-19-2007 06:35 AM
Chain skipping question Sprockethead The Workshop 12 07-24-2007 08:57 PM
