Old 02-08-2008, 10:58 PM   #1 (permalink)
Default Noisy Fox Float 36RC2
I just bought a used 07 Float 36RC2 and changed out the oil. It seems awfully noisy on rebound. It seems like it is coming from the right rebound leg. It almost sounds like air is getting sucked in through the seals as the fork is coming up. Anyone else ever experience this?
92se-r is online now
Red Hot Sloth (02-10-2008), station (02-08-2008)
Old 02-08-2008, 11:12 PM   #2 (permalink)
Is this thing on?
station's Avatar
Mine is noisy too, unless I open the rebound all the way up. It seems like the valve is creating a smaller opening for air or oil to get through and thus creating more noise. I should look at a schematic.
station is offline
92se-r (02-08-2008)
Old 02-08-2008, 11:28 PM   #3 (permalink)
What kind of air pressure are you running at? What is your weight? What about your high speed and low speed compression settings?
Old 02-09-2008, 06:18 AM   #4 (permalink)
It's normal to have some noise. Just make sure you used the correct amount of fork oil when you serviced it.
Old 02-09-2008, 02:35 PM   #5 (permalink)
i used 25cc of 7.5wt oil in each leg. is that correct?
Old 02-10-2008, 06:54 AM   #6 (permalink)
Fox calls for 25cc in each side of 7 wt. Shouldn't make much difference on the fork oil. Sounds like everything is normal with your fork.
Red Hot Sloth (02-10-2008), un-kola (02-11-2008)
Old 02-10-2008, 09:36 AM   #7 (permalink)
i rode it yesterday on some rocky stuff and it was PLUSH. Other than the noises, it worked great.
Old 02-10-2008, 02:54 PM   #8 (permalink)
Go Angels!
un-kola's Avatar
I have a 140-Float RLC and a Pushed 100-Float RLC.They both made the same noise new or after a rebuild.As long as you don't hear a clunking noise,you should be okay.- Lloyd
un-kola is offline
Old 02-10-2008, 06:34 PM   #9 (permalink)
Bike Industry Slave
biglimey's Avatar
I've got a 2008 36, that's noisy as well, talking to the fox guys, the hydraulic noise is pretty normal. A change in oil weight and oil quality (spectro full synthetic 6 ish weight) did the trick to a certain extent, it's still makes sime noise, but once you get up to warp speed you can't hear anything!!!
Seems like you'll have to weight until 2009 for a quieter 36, the new versions will have a few tweaks to the internals to quiet them down a little.
biglimey is offline
SOLD!!! 07 Fox Float 120 RL Fork slayer The Market Place 12 02-24-2008 03:18 PM
Fox Float 32 sdyeti The Market Place 8 01-22-2008 07:37 AM
Help with noisy chain guide Seat Sniffer The Workshop 16 12-26-2007 05:36 PM
2006 Fox float RLC fork SAR_boats The Market Place 0 09-06-2007 08:30 AM
mmmm, a delicious Vanilla Float pollu_sean The Workshop 17 08-20-2007 09:58 PM
