Old 02-07-2008, 09:36 AM   #21 (permalink)
northshore's Avatar
Originally Posted by Trizz View Post
there is a lot of bike websites out there, does anyone use one inparticular thats trust worthy.
http://www.utahmountainbiking.com/fix/
Hawaiian Island Creations
Ride it: dw-link.com/reasons
northshore is offline
Red Ryder (02-07-2008)
Old 02-07-2008, 09:48 AM   #22 (permalink)
Red Ryder's Avatar
Originally Posted by northshore View Post
Ha! Beat you to it by a keystroke.
Quicker than slow... it's a good day to ride!
Red Ryder is offline
Pato (02-07-2008)
Old 02-07-2008, 10:21 AM   #23 (permalink)
Although it's been said, I'll repeat it.
The brakes need to be bled properly. If done properly, your brakes will work very well.
The rubbing will mostly go away after you break in the pads. This will come in time. Nonetheless, you still may experience a slight bit of rubbing. This is normal.
If you or someone else contaminated the pads with some kind of oil or brake fluid, you'll need to replace the pads and clean the rotors with isopropyl alcohol.
Otherwise, unless there is something wrong with a particular component, just ride the bike as it is. If you find your abilities exceed the bike, or you simply have money to burn, then you should find stuff to upgrade.
Pato (02-07-2008), Trizz (02-07-2008)
Your biggest upgrade for 2008! mntbiker12 General Discussion 51 12-23-2007 05:38 PM
Avid Hyd. Disc Brake Upgrade question amor587 The Workshop 5 11-29-2007 03:00 PM
Itchin to upgrade jayman_29 The Workshop 30 09-07-2007 02:57 PM
server upgrade LBmtb Website discussion 7 08-15-2007 05:04 PM
upgrade advice mco804 The Market Place 44 05-11-2007 07:52 AM
