wild in the streets!!!
I have a 66 fork with ata & rcv. I have gotten my rebound set nice but i was wondering about the high speed compression knob, located on the bottom right fork leg.
If I understand everything right high speed compression is how fast or slow the fork will compress, or am I way out in left field. Any advice would be greatly appreciated on helping me set the high speed compression. MUCHO'S THANK YOU'S!!
todays forecast heavy 951 with a slight chance of 909.. http://www.ericmaaskesclassictattoo.com/artists.html |
high speed compression damping controls big hits. Low speed the smaller stuff and to control brake dive.
thank's that helps me out alot & answers a few quetions I had.
Hi speed damping is hard to tune. It is neerly imposible to tune it just pushing on the suspension. You can't really feal tuning changes unless you ride the fork, and know how to feel what the high speed damping is doing.
What has been said by is CalEpic accurate. High speed compression damping can stop you from blowing through travel. If you are bottoming your fork out, or if you are using more travel than seems good on medium and big hits, and the spring rate is correct, try more high speed compression damping. If you are not using much travel on big hits, but the fork is plush, turn that high speed damping out a little. |
| Help converting Hardtail to single speed. | Lambda_drive | The Workshop | 38 | 02-07-2008 08:48 PM |
| DirectTV High Def VS. Dish High Def HELP! | dirtmistress | The Pub | 16 | 01-24-2008 05:17 PM |
| No Cost Single Speed Conversion | UR2KLOS | General Discussion | 61 | 01-03-2008 07:14 AM |
| High Sierra Fall Century Write Up - Long w/ Pics | MTBMaven | The Roadie Hangout | 4 | 09-25-2007 09:28 PM |
| RR: High Meadows-Star Lake, Tahoe | dstepper | Trail Talk | 4 | 08-18-2007 12:56 PM |
