Old 02-04-2008, 09:13 PM   #1 (permalink)
Lambda_drive's Avatar
Default Help converting Hardtail to single speed.
I have all of the necessary parts to convert my Iron Horse into a Single Speed. I took off the dérailleurs and shifters, but after that I got a bit nervous, it turns out that I have no idea what I'm doing.
It would be great if someone could help me Convert my bike into a single speed. The main reasons why I want a single speed is because its very simple, its quite, to chain slap, clicking, and the main reason its much more durable than dérailleurs, plus I really hate adjusting dérailleurs.
Lambda_drive is offline
Old 02-04-2008, 09:30 PM   #2 (permalink)
gooseaholic's Avatar
well herald you really need to think about it. You need more than one bike. Do you think you want to do a 25mile ride on a single speed? Not that you cant, but youre knees will be blown in no time.So for recovery you use a geared bike and spin.A single speed is cool but you need options.
When you have more than you think, you need more space. Society you are a crazy breed,I hope you wont be lonely without me.
We are opinions so filled with hatred.
gooseaholic is offline
Old 02-04-2008, 09:40 PM   #3 (permalink)
Deer Ugly
This will get you started.
http://sheldonbrown.com/singlespeed.html
Btw, 32T chainring, and 20T cog (32:20) is a good place to start for most people doing any climbing.
freekengo: don't be a chewy and ride.
Steven Jackson: ask yore girlfriend about my dopplir.
Pho'dUp is offline
Old 02-04-2008, 09:46 PM   #4 (permalink)
To start out I'm going to gear it a bit low, besides, I don't really ride many other trails besides the fully loop, I doubt I'll blow my knees riding the fully loop every now and then. Also my friend LAW decided to lay off biking for a while, He just upgraded to a Suzuki GSXR from a ninja 250, he's pretty much riding that now and doesn't have time to mountain bike anymore, so he agreed to let me use his bike if I need to. The great part is that he's my next door neighbor. So I can just pick up the bike and give it back when ever I need to.
Old 02-04-2008, 09:51 PM   #5 (permalink)
you need to explore new trails to really mountain bike.
Lambda_drive (02-04-2008), ShinKen (02-05-2008)
Old 02-04-2008, 10:13 PM   #6 (permalink)
True, but I don't have a car, the fully loop is the closest trail to me. I usually just bike ride to it. The only other way I can get to some nicer trails is if I bum rides off of people, but I don't really like doing that, I don't like being a burden to people.
Old 02-04-2008, 10:20 PM   #7 (permalink)
Potato mtn on Thursday. I will pick you up, need to leave at 6:30 am. The ride is 25-30 miles.you want to go?
So yes you want to go? I can pick you up.
BoingBoing (02-05-2008), Lambda_drive (02-04-2008)
Old 02-04-2008, 10:21 PM   #8 (permalink)
Well, if your ok with it then sure, but here's the thing, I just took off my dérailleurs and shifters. I could put them back on, but the rear dérailleur is bent beyond repair. If I can get my bike converted before Thursday then all is well.
Old 02-04-2008, 10:26 PM   #9 (permalink)
you can use my bike again, i will ride my bighit!
Old 02-04-2008, 10:30 PM   #10 (permalink)
my other bike.Click image for larger version
Old 02-04-2008, 10:38 PM   #11 (permalink)
Did you say 6:30 am, sorry I've got class. I guess I can't make it.
Old 02-04-2008, 10:42 PM   #12 (permalink)
so do you want to go?????
Yea 6:30 am to make it to L.A by 8am.Lets do it bro.
Old 02-04-2008, 10:50 PM   #13 (permalink)
autoduel's Avatar
Put your front derailleur back on and adjust the lower limit screw so it's over your middle ring.
Get a tensioner and shorten your chain to fit the 19/20/21 cog in your cassette.
Steve
Just along for the ride
autoduel is offline
gooseaholic (02-04-2008), Lambda_drive (02-04-2008)
Old 02-04-2008, 10:53 PM   #14 (permalink)
I'd like to go, but I can't miss class, I've already got a few questionable absences...
I looked at the potato mountain thread and it sounds like it's a pretty intense ride, The fully loop is hard enough for me as it is. I'm not even sure I'll be able to finish such a crazy trail.
Old 02-04-2008, 10:59 PM   #15 (permalink)
Hence the reason I said hold off on the single speed.If things change let me know and I can pick you up.
Old 02-05-2008, 07:16 AM   #16 (permalink)
northshore's Avatar
Lamda, I can get to the Fully on Thursday around 4:30ish. Possibly if Dino and Coleko can get there, I can bring my tools along and help you with the rest? Sorry I've been busy at work! What did you end up buying for the conversion?
Hawaiian Island Creations
Make a difference: www.imba.com
northshore is offline
Lambda_drive (02-05-2008)
Old 02-05-2008, 08:10 AM   #17 (permalink)
I bought the Forte single speed kit from performance.
smaller crank screws.
PC-1 chain
I wasn't able to find an 18mm cone wrench though.
northshore (02-05-2008)
Old 02-05-2008, 08:17 AM   #18 (permalink)
autoduel's Avatar
PC-1 chain
I don't think you want to run a PC-1 chain unless you are running a single cog or taking your cassette apart. The wider chain will hang up on the adjacent cogs and want to ghost shift.
Steve
autoduel is offline
Old 02-05-2008, 08:18 AM   #19 (permalink)
northshore's Avatar
Lambda will have to take that cassette off in order to run a 20t. Only problem, I don't have the adapter to remove the cassette
Old 02-05-2008, 08:19 AM   #20 (permalink)
Sir Smack-Alot
Dino Brown's Avatar
What I think draws LAMBDA to single speeds would be the SIMPLICITY of them. Whenever he talks about them, the same words keep popping-up: simple, no more broken derailler hangers, no more adjustments, clean look etc. Like it or not, he has put MUCH thought into this decision.
Will there be a learning curve? YES! Will he suffer? Yes! Will I laugh at him when asking the question, "Soooo, how do you like SS now?" NO! Iron Horse owners never disrespect eachother!
Bottomline, the kid should be applauded for being bitten by the biking bug. Worst case secenario, he switches back!
TrailJesus- How many kids do you have that you DON'T know about
Pugz- For an Asian man he was pretty big
Dino Brown is offline
Lambda_drive (02-05-2008), northshore (02-05-2008), ShinKen (02-05-2008)
Single speed on a budget COLEKO The Workshop 236 03-01-2008 06:19 PM
single speed hard tails jackal525 General Discussion 24 02-04-2008 08:22 PM
No Cost Single Speed Conversion UR2KLOS General Discussion 61 01-03-2008 07:14 AM
Single speed...single wheel? Seat Sniffer The Pub 0 01-02-2008 02:13 PM
Single Speed World Championships 2007 mtbtec Racing and Training 6 04-18-2007 09:28 AM
