Old 02-01-2008, 06:06 PM   #1 (permalink)
Default Fox 36 or Marzocchi Z1 Light?
Which one do you guys think is better? Thoughts? Pros and Cons of each?
92se-r is online now
Old 02-01-2008, 06:30 PM   #2 (permalink)
TCB
TCB's Avatar
I have the Fox 36 Talas RC2 on my RFX, it’s soooo plush, I also like the three step travel adjust, another pulse is the 20mm quick release, in my opinion it’s the best, I also own a Pike and Marz 66 and out of the three Fox has the most secure QR.
"Keep it singletrack” stay on the trail to avoid widening the trail, on narrow singletrack stop and lean the bike to one side to allow others to pass.
SDMBA
TCB is offline
92se-r (02-01-2008)
Old 02-01-2008, 06:30 PM   #3 (permalink)
Just climb like a goat!
kbteachme's Avatar
A lot of people are happy with their Talas or Vanilla 36. However, I think there will be less problems with the Z1 Light, but they are very hard to find on the used market. I'm in the market for one right now, but I'm also thinking about getting the Marzocchi 55.
kbteachme is offline
92se-r (02-01-2008)
Old 02-01-2008, 07:14 PM   #4 (permalink)
Bike Industry Slave
biglimey's Avatar
As long as you get the new 36, i'd go that way, a ton plusher than the old one, otherwise the MZ is pretty smooth. Ditto to TCB on the solid feel, but given the choice I'd run a RS Lyric first. I have a solo air that's insanely smooth...But the FOX is damn solid!!!!
biglimey is offline
92se-r (02-01-2008)
Old 02-01-2008, 07:51 PM   #5 (permalink)
Default bombers rule
z1 light if you dont want to change seals every 6 to 9 months.have z1 light and have hade no problems for 2 years now.have never had fox fork that seals lasted more than 9 months.
neg1977 is offline
92se-r (02-01-2008), kbteachme (02-01-2008), tkblazer (02-02-2008)
Old 02-02-2008, 10:15 AM   #6 (permalink)
were you at aliso today? i overheard someone saying that exact same thing!
ditto on the Z1 light dood, i ran one on my old Reign and it was the shiz... i'm currently running it at 5" on my hollowpoint and its freakin a sick setup
Old 02-02-2008, 10:52 AM   #7 (permalink)
On the Z1, since it has a coil, will I have to swap springs to a lighter one? I only weigh 145.
Old 02-02-2008, 11:01 AM   #8 (permalink)
nope, there is an air preload so you can just not run any air in the chamber... if that is still too stiff, i'm sure you can change the spring out...
Old 02-02-2008, 11:04 AM   #9 (permalink)
What kind of settings did you guys run on your Z1's?
Old 02-02-2008, 11:10 AM   #10 (permalink)
i don't remember my rebound and compression settings... i don't use too much rebound damping, maybe 7-8 clicks from full open, compression might be like 2-3 clicks from full open... 30 psi in the air preload to keep the front end up and not drive when on the brakes
Old 02-07-2008, 03:35 PM   #11 (permalink)
Oil heights are key for tunning Zokes. Unlike the Fox offereings where there are a plethora of spring rates, the Zoke coil forks use oil height adjustments to get you in the ballpark for your compression dampening characteristics.
Zokes has the oil level tables on their website to get you started. When tuning my 66, tweaking the oil levels made the difference between adjustments that did very little, to putting everything right in the middle of the adjustment range where changes could then be felt.
Chris
Flat Broke is offline
Old 02-07-2008, 06:17 PM   #12 (permalink)
Faith Driven
Happy_Gilmore's Avatar
Thumbs up
Z1 Light = R17 clicks-in / C4 clicks-in / 40 psi, can't say enough good about this fork (06, Foe's FXR 2:1)
Happy_Gilmore is online now
How I Built My Own MTB Light BrewMaster The Workshop 131 04-14-2008 07:48 AM
Jet Lites Phantom 20W Halogen helmet light tkblazer The Market Place 6 01-30-2008 03:27 PM
SOLD!!! 2006 Marzocchi Z1 Light with ETA $250 dstepper The Market Place 9 01-24-2008 08:39 PM
Night Lights Pain Freak General Discussion 25 08-07-2007 07:44 AM
Pike 454 or Marzocchi Z1 Light DK5Spot The Market Place 2 07-16-2007 09:11 PM
