I have UGI
I've started collecting parts for my next wheel build. These will be for my XC FS 29er, which will primarily used for endurance races and rides.
I'll be lacing Stan's Arch's (29) to XTR M975 hubs. I was just going to go with DT Comp spokes, but can I get away with something lighter? Maybe the Supercomps? What do you guys think? I'm 175lbs (w/o gear) |
station (01-30-2008)
I used Comps on my recent build, and so far they seem to be doing well for a 200lb rider.
My advice though is more about the length: make sure you get the right length. The guy at Beyond Bikes talked me out of the lengths I went there with and I left with spokes that were too long. Now I can't get the wheel tensioned tight enough because I've run out of thread.
My Blog |
Peters Canyon Warrior
I hope one of the Mann's chimes in here.
I have a AM Classic Disc/Stan's Arches built with double butted spokes. Wicked light hubs, but wheels still came in at just under 1800gm. So that might be a good marker for you. Are you pretty rough on wheels Dubjay? And if you're using these for Endurance races I wonder if that last 100-200 grams are worth it considering you' wouldn't want to bust a wheel 30 miles into 50mile race. |
I have UGI
Wheels usually hold up pretty well for me. The only time I have issues is when a branch or rock gets stuck in them and end up tweaking a spoke or two.
Weight savings would actually be minimal. According to DT's spoke calculator, the wheelset would weigh in at 1811g with the Comps, and about 1760g with the Super Comps. I think I might just stick with the Comps to keep it somewhat durable. I know with the last set of Stan's rims I built up, they don't like a lot of spoke tension. I just don't want to end up with something too flexy. I'm thinking of going with the Bontrager Dry X tubeless. I like what you said about the steel tire iron. And yes, I put 29er in the title just to grab Foo's attention.. |
Oooh man.. I don't pay a ton of attention to spokes (except on my uber 29er wheels).
I believe when we get my lighter Canzo wheelset built I'll be using double butted spokes and alloy nipples. I *think* that Justin has the Revolutions on his burly wheelset (which is what I'm running right now). For 29er... if I wasn't sure (didn't have Justin around to ask) I'd either email MikeSee, or talk to Brian/Donkey. Mike builds 29er wheelsets basically for a living ![]() |
dubjay (01-30-2008)
#10 (permalink) | |
I am shocked that some people, non XC racers anyway, would use revolutions and some folks wont even build wheels with revoluations when disc brakes are involved, 26er or otherwise. For what it is worth, for a 26er, for hard XCing for example, I, at 175 lbs, would use supercomps up front and woudl use them on non-drive side out back. On similar bike (ie, XC/AM FS bike) in 29er, i bump it up to Competition FOR SURE given the relative lack of stiffness from the longer spokes. I would definitely not bother with anything wimpier than Comps myself.....many say i dont know that the hell i am talking about though but you did ask....heck, its not like comps are even heavy. |
iSlay
throw a set of these on and call it a day.
BrewMaster (01-31-2008),
Pho'dUp (01-30-2008)
Comps should be great.
Revolutions will be pushing it, but could work out. Maybe try Supercomps. We mostly do Comps for wheels like this, but we will do Supercomps in some cases, and it ususally works out. The main weekness of Revos and Supercomps in my opinion is that they are a little more vulnurable to rocks. I have Supercomps (almost as light as revos) on my 29er, but I weigh 155 and that is my lightes bike. I once pinged a spoke off a rock protrusion and it broke. I feel like a Comp would have survived that incident with a dent and gouge, but it's hard to say for sure. Karl has been known to get away with Supercomps on a 29er wheel, and he is around 2 bills. He rides hard too. I think these questions about wheels always come down to the individual. Rider size is definetely a factor, but there are lots of other factors. In the end, if you want to push the weight savings envelope, you have to experiment a little and find out what works for you. Flex may also be a concern. |
#20 (permalink) |
life is indeed crazy as ever....2007 was perhaps the worst year of my life, short of having a divorce or losing a loved one. still crazy busy but looking up....my sandbagging days are definitely over but i do plan to get into shape by summer for sure! cant wait to ride with you again my friend
