Old 01-25-2008, 01:30 PM   #1 (permalink)
Roadstar_Rider's Avatar
Default Tire seems out of shape
I bought a set of WTB Velociraptor tires for my bike. The back one is good, but when I put the front one on and spin the tire, it looks like my wheel is bent. I had a free tune up done at the place where i bought my bike and they put the wheel on a machine to check it for bends and they said that there is nothing wrong with the wheel, that its the tire.
Does this matter? Is this common in tires for them to look a little off?
Roadstar_Rider is offline
Old 01-25-2008, 01:34 PM   #2 (permalink)
northshore's Avatar
Maybe the tire bead is not seated correctly?
Hawaiian Island Creations
Ride it: dw-link.com/reasons
northshore is offline
Roadstar_Rider (01-25-2008)
Old 01-25-2008, 01:38 PM   #3 (permalink)
Padre's Avatar
It's common. Check the bead, if the bead is fine, I'd use it.
Even though that tire is a relic, you should be fine.
I've been running a Specialized Fast Trak with a notable wobble for months. Just check the bead for safety's sake.
Cowboy.
padre29 AT mac DOT com
Padre is offline
Old 01-25-2008, 01:58 PM   #4 (permalink)
I'm outa shape, too, but I seem to do ok. It's common for tires to have wobbles in them, even though the rim is straight. Assuming that beads of the tire are seated correctly, just run it. Kenda tires are also typically bad in this regard whereas most of the Maxxiss tires I've had have been generally pretty good.
If the beads aren't seated, and they are a bit difficult to seat, air down the tire, then spray window cleaner or a soapy solution all around the bead on both sides, then air up the tire.
RacinJason (01-26-2008), Roadstar_Rider (01-25-2008)
Old 01-25-2008, 01:59 PM   #5 (permalink)
Now a GloryDH rider
stinkyrider's Avatar
I believe the tire is no properly seated in the bead.
I had the same thing with my tire. I had to pump the tired up to about 70 psi until I heard the bead pop into place, then dropped the psi down to 35-40. It seemed to do the trick, no more wobble. I hope I didn't damage my wheel or anything else by do that.
stinkyrider is offline
Alex (01-26-2008), Roadstar_Rider (01-25-2008)
Old 01-25-2008, 02:01 PM   #6 (permalink)
ghixon's Avatar
But yet you seem to make everyone look silly out there...
ghixon is offline
2wheel_lee (01-25-2008), northshore (01-25-2008), Pato (01-25-2008), Roadstar_Rider (01-25-2008), speckledtrout (01-26-2008)
Old 01-25-2008, 02:08 PM   #7 (permalink)
Well, I don't know about silly, but you'll note that you usually see me riding downhill...not up.
ghixon (01-25-2008), Pato (01-25-2008), RacinJason (01-26-2008), Roadstar_Rider (01-25-2008)
Old 01-25-2008, 02:44 PM   #8 (permalink)
Rob's Avatar
If you can't get it to seat properly with just air you might need to use one of these tools.
http://www.parktool.com/products/det...17&item=PTS-1#
Rob is offline
Red Hot Sloth (01-26-2008), Roadstar_Rider (01-25-2008), stinkyrider (01-25-2008)
Old 01-26-2008, 07:45 AM   #9 (permalink)
SoCalMTBubbs
Schecky's Avatar
I use one of these tools
Chewyeti: Sam and I banged it out this morning. LOVE THAT
http://www.ventanausa.com/
Schecky is offline
OMR (01-26-2008), Pato (01-26-2008), Red Hot Sloth (01-26-2008), Roadstar_Rider (01-26-2008), Waldo (01-26-2008)
Old 01-26-2008, 07:50 AM   #10 (permalink)
Don't let your significant other catch you.
foofighter (01-26-2008), Pato (01-26-2008), RacinJason (01-26-2008), Roadstar_Rider (01-26-2008), Schecky (01-26-2008), Waldo (01-26-2008)
Old 01-26-2008, 10:36 AM   #11 (permalink)
ghixon's Avatar
Wink
Too Late
ghixon is offline
1FG rider (01-26-2008), foofighter (01-26-2008), jeffj (01-27-2008), OMR (01-26-2008), Pato (01-26-2008), RacinJason (01-26-2008), Red Hot Sloth (01-26-2008), Roadstar_Rider (01-26-2008), speckledtrout (01-26-2008), Waldo (01-26-2008), xhuskr (01-26-2008)
Old 01-26-2008, 02:32 PM   #12 (permalink)
OMR
OMR's Avatar
Talking Errr, grasshopper...
Isn't there a chance you might go blind if you use one of these?
Or your tongue would grow hair???
OMR .... An elder grasshopper of the Tribe
The journey is the thing .... ride like it's your last one...
OMR is offline
Pato (01-26-2008), Roadstar_Rider (01-27-2008)
Old 01-26-2008, 04:04 PM   #13 (permalink)
SoCalMTBubbs
Schecky's Avatar
....to seat tires......
Schecky is offline
Old 01-26-2008, 07:31 PM   #14 (permalink)
i thought you would get hairy palm?
www.coverageispersonal.com
foofighter is online now
Nevegal Tire Knobs coming off Sprockethead The Workshop 24 05-02-2008 04:12 PM
Happy Monday - Tire Murder Mystery scruffylooking General Discussion 39 01-21-2008 07:49 PM
Tire problem Dino Brown The Workshop 22 12-26-2007 08:34 PM
Mt. Sac Fat Tire Classic 11/4/07 denmother Trailhead 103 11-03-2007 09:58 PM
Attn Rubber Gurus! Find me a tire!? Pho'dUp General Discussion 8 06-24-2005 10:07 AM
