Old 01-24-2008, 07:25 PM   #1 (permalink)
nintense's Avatar
Default Maxxis High Roller UST with Cancer ...
This is a 6 months old High Roller 2.35" UST LUST tire that run on Stan's.
Did anyone see something like that ?
nintense is offline
Old 01-24-2008, 07:26 PM   #2 (permalink)
Stan's is bad for your tires in some instances. Warranty won't cover that.
See here
It looks like the bead on your tires is pretty torn up. I don't think sealant will do that.
nintense (01-24-2008)
Old 01-24-2008, 07:28 PM   #3 (permalink)
RacinJason's Avatar
looks like you broke all the belts that hold the tire together.
did you hit something hard enough to bend the rim?
RacinJason is offline
Old 01-24-2008, 07:32 PM   #4 (permalink)
Free-XC-Downhiller
SSinGA's Avatar
I've seen it before and it's not isolated to Maxxis.
www.t2bikes.com
SSinGA is offline
Old 01-24-2008, 07:34 PM   #5 (permalink)
someone posted this not too long ago w/ the same problem
www.coverageispersonal.com
foofighter is offline
Old 01-24-2008, 07:44 PM   #6 (permalink)
Rob's Avatar
My Maxxis Ignitor has an acne problem
Rob is offline
foofighter (01-24-2008)
Old 01-24-2008, 07:45 PM   #7 (permalink)
good find rob i tried but used wrong search word LOL
Rob (01-24-2008)
Old 01-24-2008, 07:46 PM   #8 (permalink)
Rob's Avatar
I remembered the keyword Acne
Rob is offline
speckledtrout (01-24-2008)
Old 01-24-2008, 07:53 PM   #9 (permalink)
nintense's Avatar
Default Thanks for the link...
See here
They talk on a non tubeless tires, this is a UST tire that should works properly as a tubeless.
I had a good experiance with Maxxis tires (UST and converted) for the last few years, it's the first time I see it on a UST tire.
nintense is offline
BrewMaster (01-24-2008)
Old 01-24-2008, 07:55 PM   #10 (permalink)
I was just using that an example of how manufacturers approach the subject. Basically, they leave you on your own with that.
Old 01-24-2008, 08:02 PM   #11 (permalink)
Koke's Avatar
I've had the same problem with 3 Specialized Fast Trak S-WORKS tires. Stans eats the inside of the tire.
Koke is offline
Old 01-24-2008, 08:18 PM   #12 (permalink)
Rob's Avatar
Specialized makes a fluid you can use in tubeless tires.
http://www.specialized.com/bc/SBCEqP...jsp?spid=26623
Not sure if it'll have the same problem in Maxxis tires. Worth a shot maybe.
Rob is offline
BrewMaster (01-24-2008), Koke (01-25-2008), nintense (01-24-2008)
Old 01-24-2008, 08:39 PM   #13 (permalink)
speckledtrout's Avatar
oh dear. didn't want to hear that. i'm running stans on my fast trak tires on my niner. the bike shop set them up when they built up the bike and i assume they used stans and not the specialized stuff. eek. i'll keep my eyes peeled. (as painful as that sounds.)
speckledtrout is offline
Old 01-24-2008, 09:07 PM   #14 (permalink)
I have UGI
dubjay's Avatar
Wow..yours is pretty impressive..mine only had a bunch of little bumps.
If you want to see some cool stuff, try lancing it with a needle..
dubjay is offline
nintense (01-24-2008), speckledtrout (01-24-2008)
DirectTV High Def VS. Dish High Def HELP! dirtmistress The Pub 16 01-24-2008 05:17 PM
anyone with maxxis... socal ridur The Market Place 3 08-23-2007 05:57 AM
Cost of Paying for Cancer Treatment is Sad foofighter The Pub 12 08-02-2007 09:10 PM
Maxxis Advantage 2.4 or High Rollers boboso General Discussion 2 06-25-2007 04:02 PM
Maxxis High Roller 2.35 for $32 tkblazer The Market Place 12 06-11-2007 09:36 PM
