Good Grasshopper
i accidentally squeezed the front brake lever, now the pads are rubbing to the rotors, i can spin the wheel freely, it would spin a few then to a dead stop. How can i fix this?
its an avid juicy three, hydro. brakes. note: i took the front tire to load it to my civic coupe 2D, and as i lift the bike, i accidentally squeezed the brake lever.
Climbing, You Know You Want To. |
Did you do this with the wheel out..I'm guessing you did.
Remove your wheel. Some brakes come with a seperating tool like the Hayes. Use it to spread the pads. Re-install wheel, grab a little brake, release, grab again...should be good to go. If you do not have this tool, use a smalll boxed end wrench...after removing wheels and pads, apply pressure to piston, making sure not to touch/bend post, repeat with other piston. Re-install pads, wheel , grab brake, release, grab brake release, should be good to go. *Edit: This is if you have Hydro's and not mech's |
Uphill Shuttle Monkey
I have mech disks and whenever I get rubbing, I just spin the wheel and grab the brake hard. Sometimes that's all it takes. I'd try a couple or three times.
But I don't understand how your issue started. Aren't you supposed to squeeze the front brake lever?
...if I'm sweaty and dirty, I must be having fun... |
JOx2 (01-24-2008)
BoingBoing (01-24-2008),
JOx2 (01-24-2008)
squeeze em again... and you will have pistons on the floor :O
just push the pistons back into their bores with a flat object.... (spread the pads... pushing the pistons back in)
Chewy THE Yeti Call me Chewy or Aaron VOODOO Gonzo 29 Big Boys ride.....BIG wheels. |
JOx2 (01-24-2008)
| Disc Brake Help | jason1234 | The Workshop | 9 | 12-26-2007 01:06 PM |
| Hayes Brake Rotors & Pads | project_d | The Workshop | 10 | 10-17-2007 08:40 PM |
| Brake lever pin missing | Paul000 | The Workshop | 4 | 08-07-2007 11:09 AM |
| disc brake pads?? | number7s | The Workshop | 3 | 07-24-2007 08:33 PM |
| Frustrations with new brake pads!!! | i am dino | The Workshop | 13 | 02-23-2006 08:41 AM |
