Old 01-23-2008, 05:21 PM   #1 (permalink)
tkedeuce231's Avatar
Default front derailleur won't allow shifting
A couple of days ago I went to my local trail in order to do some trail work. On my ride back home I ended banging my front drailleur on a rock due to the muddy conditions. Due to my little spill my front derailleur will not shift gears. Any ideas on how to fix? Should I just try and bend it back into place? Or how do I know if it is my shifter pod that is busted? Thanks for your help.
tkedeuce231 is offline
Old 01-23-2008, 05:49 PM   #2 (permalink)
Rob's Avatar
Any way possible to post a pic?
Is it a clamp on type or e type der?
Rob is offline
Old 01-23-2008, 06:08 PM   #3 (permalink)
i know its simple but if it moved or bent down more then 1/8 of an inch it might be hitting the chainrings when u shift
Old 01-23-2008, 08:59 PM   #4 (permalink)
The GF has my digital camera, but it is a clamp on der.
Old 01-23-2008, 09:08 PM   #5 (permalink)
Rob's Avatar
If the clamp hasn't slipped and it is indeed bent, I'd go ahead and try to bend it back. But make sure it is definitely bent and not just slipped out of place.
If the clamp just slipped, loosen up the clamp, realign it and then set the set screws.
Here's the procedure from Parks website.
http://www.parktool.com/repair/readhowto.asp?id=75
Rob is offline
tkedeuce231 (01-30-2008)
Old 01-23-2008, 09:22 PM   #6 (permalink)
Lebowski Urban Achiever
Waldo's Avatar
Or you could follow Vickie's lead and buy a new bike!
"My ass is sore after a long ride." - MtnKitty
" If you feel like you're going fast, you are!" -CalEpic
Waldo is offline
bighit8 (01-23-2008), Rob (01-23-2008)
What Front Derailleur for Niner MCR? MTBMaven The Workshop 4 01-14-2008 08:26 PM
XTR Front Derailleur 31.9mm $40 Keith B The Market Place 5 02-26-2007 10:13 AM
NIB Front XTR Derailleur Rob The Market Place 4 02-25-2007 06:48 PM
long throw/short throw rear derailleur? witt The Workshop 9 09-08-2006 06:49 PM
shi+mano front derailleur help mrpoonerson The Workshop 3 09-25-2005 11:41 AM
