Old 01-23-2008, 07:30 AM   #1 (permalink)
Default Integrated headset vs Reba fork
I am trying to help a friend put a Reba frok on a GT i-drive team and it has an integrated headset and the Reba is apparently not designed for this.
How do we get the fork to work with this setup??
THANKS!!!
"It doesn't get any easier, you just go faster." Greg LeMond
schleppp is offline
Old 01-23-2008, 07:34 AM   #2 (permalink)
RIP Gene
DeeZee's Avatar
Default What
THANKS!!!
exactly is the issue
DeeZee is online now
schleppp (01-23-2008)
Old 01-23-2008, 07:42 AM   #3 (permalink)
Are you sure you have the correct headset baseplate/ lower race? It should be a simple install.
2wheel_lee is online now
DeeZee (01-23-2008), schleppp (01-23-2008)
Old 01-23-2008, 07:42 AM   #4 (permalink)
bikeaholic
bikeadict's Avatar
I don't see any problem. I doubt the fork cares if the headset is integrated or not as long as the race that you put on the fork matches up to the headset. Are there clearance issues???
You probably need to be more specific concerning the issue.
bikeadict is offline
Old 01-23-2008, 07:48 AM   #5 (permalink)
The first problem is that neither of really knows what we are doing... That being said, yes there are clearance issues. The bottom of the headset, the integrated portion, is sitting on the fork and not allowing the fork to move...
To clarify: I ride bikes and really do not work on them so help me with some terms:
Race? is what?
base plate?
schleppp is offline
DeeZee (01-23-2008)
Old 01-23-2008, 07:58 AM   #6 (permalink)
Ghetto Swan Lake
Did you remove the crown race from his old fork and install it on the Reba?
Something sounds very wrong here.
Pho'dUp is offline
Old 01-23-2008, 08:02 AM   #7 (permalink)
RIP Gene
DeeZee's Avatar
Default Ok
Race? is what?
base plate?
I have installed forks with intergrated HS's and the Reba should fit fine.
First make sure the Race/ Base plate / etc... is installed correctly. The machined smooth size should be facing the bearings / head tube.
Next look at the bearings. There should be two sets. Are they the same size? If not "I think" the larger ones (thicker) will go on the bottom closest to the fork.
Make sure the bearings are installed facing the correct direction
Old 01-23-2008, 08:16 AM   #8 (permalink)
Pato's Avatar
Race? is what?
base plate?
Sounds like new fork install on an old existing frame/headset correct? If this is the case, you will have to either remove the (crown) race or base plate (two names for the same thing) from the old fork or buy a new one. The race is specific to the brand/model headset you have btw. It's that steel piece that was press fit onto the fork crown (where the steer tube meets the rest of the fork).
If you did not install the race onto the new fork first then the fork will not rotate as the lower bearings will not be in contact with the fork and the fork will bind to the head tube on the frame when you tighten the top cap bolt.
Duc
Pato is offline
Old 01-23-2008, 08:17 AM   #9 (permalink)
Since you commented that you don't know what you're doing, are you sure you don't have an internal headset on an integrated headset frame, or have an integrated headset on an internal headset frame?
Old 01-23-2008, 08:26 AM   #10 (permalink)
I think it is an integrated headset on an internal headset frame...
But I don't know... I guess I am just going to tell him to take it to a LBS.
schleppp is offline
Old 01-23-2008, 08:34 AM   #11 (permalink)
ghixon's Avatar
Hey Schleppp
I'm here in Riverside. If your buddy or you wants I can take a look at it and give him some help. I did the same change on my '05 1.0 I-Drive. It really isn't that hard.
PM me or post up.
Greg
ghixon is offline
Old 01-23-2008, 08:42 AM   #12 (permalink)
Thanks to all of you... But I am going to let him deal with it!! I will just go with him when he drops it off. Maybe I will learn something!!
Thanks again!!
schleppp is offline
I need a Reba 29er fork Uncle Rico The Market Place 3 01-25-2008 12:00 PM
Integrated Fork on Non-Integrated Frame MTBMaven The Roadie Hangout 3 01-21-2008 03:30 PM
REBA 4" fork 0gravity The Market Place 12 11-20-2007 02:19 PM
Reba Fork Service DeeZee General Discussion 10 07-13-2007 02:27 PM
Manitou Sherman Breakout Plus fork for sale TURNERob The Market Place 1 06-25-2006 01:54 PM
