#21 (permalink) | |
Let's see... Stans Flow x2 @ $75 each Hope Pro II Hubs @ $265 for the pair Sapim CX-Ray x64 @ $2 each. Alloy nipples x64 - I don't know..like $5? Like $550? Not including the beers I drank while building them ![]() |
northshore (01-22-2008)
#22 (permalink) |
Sir Smack-Alot
First of all- you must decide on the intended purpose of the bike. If you want a weight-weenie bike- go light! I say the best thing to do is: shave off some weight (and plenty of rolling resistance) by upgrading the wheelset! Done!
Confused about the pedals though. Your bike should have been delivered with SMARTY pedals. The bike should weigh 30.8 pounds! Mr. Epic is absolutely correct: Any lighter and you lose trail worthiness! With regard to tires, I use a 2.3 High Roller up front.... Ignitor in the back. Lovin' it! You could always lose 2 pounds. Won't cost you a thing!
L.A. KINGS ... dw-link.com/reasons SheDevil- I was on George's crotch for hours Integradriv3r- How many kids do you have that you DON'T know about? Genusmtbkr5- I like to go BOTH ways |
#23 (permalink) |
Preman Hater
how heavy is your horse anyway? it can't be more than 31lbs??? eh?
#24 (permalink) | |||
![]() Quote:
well, I sold my race car....hmmmm HAHAHAHAHHA dang it! |
Dino Brown (01-22-2008)
#25 (permalink) | |
Preman Hater
30lbs AM bike is really is not a heavy bike. |
#26 (permalink) | |
Yes, it did come with Smarties but I sold them to El Dood in S.D. I didn't really liked how they felt on my fat feet either. |
#27 (permalink) |
Team Sting-Ray
Titanium V-brakes--or better yet, cantilevers--instead of discs
One-piece carbon fiber bar/stem combo Mythos 1.9 tires Purple anodized cranks, seatpost and headset (everyone knows purple ano is lighter) ![]() Honestly, I don't see why you'd want to lighten that bike. The weight is likely right where it should be for its intended purpose. Enjoy it for what it is, i say.
"In bar light, she looked all right. In daylight, she looked desperate." -- Craig Finn |
bighit8 (01-22-2008)
#28 (permalink) | |
Sir Smack-Alot
What I am trying to say is: try a (lightweight) tire combo with less rolling resistance FIRST! If that is not enough, a quick wheelset will do the trick!
#29 (permalink) |
I have never owned a bike that was less than thirty lbs. I will never understand the big fuss on weight. Just pedal damn it.
singletrack angel: is that a real hole Fred? Mtbnbikefred: Yes,I have stuck all kind of things in it. |
#30 (permalink) |
I was recently researching platforms. The lightest, but not necessarily the lowest profile, were the MG1s from wellgo. 378g. they can be had for under $50 and come in more colors than a clown's dick.
I had once switched bikes with a more conditioned rider mid climb. my mkiii for his spec fsrxc. I beat him to the top. Even non rotational mass affects your climbs, at least from my experience. |
#31 (permalink) | |
![]() Oh...and I can vouge for the Wellgo MG-1's...super light, and tough ![]() |
#32 (permalink) |
Here are some wheels at a good price, front wheel just $70, centerlock adopter at Jenson for $18 if you need it
http://www.nashbar.com/profile.cfm?c...%20%2D%20Front http://www.nashbar.com/profile.cfm?c...s%20%2D%20Rear Check out the specs on the Sette parts at price point, they are often lighter than the big brands, I've got nothing but good things to say about there stuff. I have Easton Monkey lite carbon bars that have done me well, had them for at least 3 years, crashed a few times. I inspect them often no sign of cracking or damage. http://www.pricepoint.com/subList-22-Sette-Products.htm I got an Easton Havoc Wheelset super cheep & those wheels rock too
Ya that's right! |
#33 (permalink) |
bighit8 (01-22-2008),
el_d00der1n0 (01-22-2008),
northshore (01-22-2008),
Pato (01-23-2008),
Red Hot Sloth (01-22-2008),
Waldo (01-22-2008)
#34 (permalink) |
Dirty Boo (02-01-2008),
Seat Sniffer (01-22-2008)
#35 (permalink) |
Team Brittle
Just so you can put those numbers to actual use
100g = 3.5 ozs 200g = 7 ozs 400g = 14.1 ozs 500g = 17.6 ozs = 1.1 lb 1650g = 3.63 lbs 1750g = 3.85 lbs 2000g = 4.4 lbs
#36 (permalink) |
Team Brittle
Pedal efficiency has a lot to do w/ it also...lose all the weight you want but if your bike bobs you aren't efficient which means you're slow...not necessarily heavy
#37 (permalink) |
JfromLV Fan Club Prez.
easy, drill holes in everything, including the chain. several holes! helium in tubes (or even if tubeless). ditch the grips, brakes, and all shifting equipment and go to a single speed set up. take all the padding off the seat to bare plastic and sand the plastic smooth. cut seatpost off 1mm after insertion into frame. cut bars 4" on eachside. above all, make sure you know im kidding.
#38 (permalink) |
I'm going the cheapest route first. Dino's recommendation on tires and then pedals. Dino, correct me if I'm wrong but aren't the Maxxis high rollers a modified version of DH tires? They seem heavy! I do see some deals on the Ignitors though!
