I used to have the same problem, rim tape that comes standard on rims usually move around exposing the sharp edges within your rim. *Solved the problem pretty easily by going all the way round the inside of the rim with an adhesive form of rim tape or electric tape.
good times
Found 10 thorns in my front tire from that day in Turnbull. Little suckers they are.
Grab your last tube that you had, inflate it and stick it under water to see where the bubbles come out. If it's a little hole(s) it might be a thorn.
My Twits tkblazer: wonder if i can wear my yellow speedo me: only if you wear the matching yellow goggles with it |
I'm sure this is not your problem, but since we're on the subject...The toughest tire I ever dealt with turned out to be a problem where the tire liner ("Mr Toughie") got old and bits of innertube hardened and stuck to it and were sharp enough to punch holes in the new tubes. I stopped using the liners after that and I always change my tube whenever I change my tire. Super unusual problem but of course it started when I was 100 miles from home in Mt Pinos. Most likely culprit is thorn or rim tape missing. Another tip is to use a good floor pump. I used to use one of the little frame pumps and was constantly abusing the presta valves. They are very fragile, so be careful not to bend the little screw-in stem even when using a floor pump.
| Back from a 10 year hiatus | dazedone | Introduce Yourself | 10 | 07-17-2006 07:23 PM |
| I'm BACK! :) | jinks | General Discussion | 6 | 04-24-2006 08:30 AM |
| Aliso/Woods to LCWP back to Aliso/Woods with pix | i am dino | Trail Talk | 10 | 11-22-2005 09:41 AM |
| Attn Rubber Gurus! Find me a tire!? | Pho'dUp | General Discussion | 8 | 06-24-2005 10:07 AM |
| Back Spasms!! Ouch! | jinks | General Discussion | 11 | 06-07-2005 09:06 AM |
I'm not sure why but i think its because of some sharp edges on my rim
Should i file it down? Anyone have any sugestions.
