Old 01-10-2008, 09:37 PM   #1 (permalink)
number7s
number7s's Avatar
Default crank arm coming lose
my left crank are on the cannondale f5 keeps coming loose, ive tried loctite on the bolt, the bottom bracket is square taper, i cleaned all the dirt and grease but after about a mile the thing it completely loose, i cant figure out why, Bent arm?
number7s is offline
Old 01-10-2008, 09:42 PM   #2 (permalink)
is it visibly bent? I use a set of bent arms but they're not too bad. If you have a steel square taper and an alloy crankarm that was overtightened at one point, it may have loosened up and now bottoms out on the spindle. Or the spindle could be worn. Try turning it one flat forward or back and mounting it there? I usually tighten to 40-45nm.
Seat Sniffer is offline
number7s (01-10-2008)
Old 01-10-2008, 09:47 PM   #3 (permalink)
number7s
number7s's Avatar
thanks ill try that
number7s is offline
Garage Sale - Fox Forks / Crank Bros Eggs Ti / Shoes / Moab Frame / XTR Pods and Rear boboso The Market Place 12 01-04-2008 10:27 PM
Crank Set for Beach Cruiser/Coaster Brakes TwoLeggedHorse The Market Place 0 10-08-2007 01:35 PM
New Crank Brothers Goodies CeeDubb General Discussion 9 09-10-2007 09:54 PM
Anyone have cleats for Crank Bros pedals?? PacMan General Discussion 20 08-28-2007 09:22 PM
Jeff is coming down from Kernville jfsh Trailhead 11 01-19-2007 10:35 PM
