Climbing is my nemesis
I live in a coastal climate (as many here do I'm sure - I happen to be in Camarillo) and have noticed lately that some of the bolts on my 888 fork, my brakes, etc. are starting to get a little rusty. While I'm reasonably sure that this won't realistically affect the strength of the bolts, I'm "picky" about how my bikes look - even if I beat them up on the weekends!
My question is this: I’m assuming that these bolts are hardened steel of some sort. If I switched them over to stainless steel to keep them from rusting, is there a special “type” that I need so that I don’t jeopardize the strength of things? Thanks in advance, jebfour |
station (01-02-2008)
You shouldn't have any problem replacing carbon steel bolts with stainless steel. Make sure you use anti seize or grease on the threads to prevent galling. Particularly if it screws into aluminum. You can also clean up rusted bolts by dipping them in muriatic acid dilluted 50% with water. (pool acid - make sure you don't breathe the fumes)
I wouldn't worry. Most stainless fasteners are going to be 18-8 (any number of alloys) Stainless and that will be plenty for what you are using it for. It's actually pretty hard to buy a crappy stainless fastener, just get them from a reputable supplier.
Steve Peat Wannabe
As others have said, you should be o.k. Just make sure to put a bit of anti-seize on the bolts. Galvanic corrosion could occur, causing the bolts to lock up, and the anti-seize will prevent this. Stainless will be heavier, though. Though I'd mention that in case you are weight sensitive. You could seek out Ti bolts.....
scrub them with steel wool. it works really well
Brandon FLOres
You measure yourself by the people who measure themselves by you. This is How we do it! ![]() |
northshore (12-30-2007)
PORKCHOP SANDWICHES!
clean w WD-40, clear coat them.(clear fingernail polish works well for bolt/hex/torx heads)
Don't do anything by half. If you love someone, love them with all your soul. When you go to work, work your ass off. When you hate someone, hate them until it hurts.
Evel Knievel (01-02-2008)
Shrek must be destroyed
a great source for online hardware is mcmaster.com
i practically live at the mcfadden dale store in corona
| Frame sizing question... | Jman | The Workshop | 9 | 11-25-2007 07:36 PM |
| Rear hub question... | gurp13 | The Workshop | 21 | 11-12-2007 09:50 AM |
| Light question, but not the usual one. | Rascal | General Discussion | 6 | 08-13-2007 04:59 PM |
| Hydrolic brakes failure question... | JoeTruth | The Workshop | 39 | 08-08-2007 03:20 PM |
| Question about Mavic rims... kind of a tech question | Stray_Bullit | General Discussion | 4 | 12-03-2006 02:48 PM |
