Old 12-28-2007, 07:21 PM   #1 (permalink)
Default First Run at Wheelbuilding
Like a Jedi to his light sabre, I don't think my training as an MTBer is complete until I have built a wheel. For Christmas, my wife gave me hubs and a rim (next time I'll send the same link 2x ). I got spokes and nipples today and sat down to build the front wheel.
The spokes took some doing to get the lengths straight. I have come up with about 4 different versions of what the lengths should be. I went to Beyond Bikes today to buy what DT's calc said after adjusting the ERD to Mavic-tech's spec. The wrench there said their calc was more accurate. He was concerned that there was a 3mm difference between my calc and his, so he called the guy that builds Atom wheels. Apparently he used to work there. Anyway, in the end, I left with a bundle of spokes all of equal length. The wrench threw in some spoke prep too.
I chose Zinn's MTB Maintenance as my guide.
Here's the setup:
First set of spokes in:
Second set:
More spokes in:
All in:
From there all I had to do was dish, tense, and true.
Getting the tension has been problematic as the spokes are just a little too long on the rotor side. I think I've got it where it's good enough now. They make music, but it's not as high pitched as some of the other wheels in the garage.
My Blog
53-12 (01-04-2008), bajamtnbkr (12-28-2007), ChipsandSalsa (05-22-2008), Dino Brown (12-28-2007), dudevf1 (12-29-2007), JOx2 (01-04-2008), Marshall Willanholly (12-28-2007), mazda-monkey (01-04-2008), mtnbikerfred (01-04-2008), OffRoadie (12-31-2007), PacMan (01-04-2008), sladnas (12-28-2007), slayer (01-11-2008), TCB (01-04-2008)
Old 12-28-2007, 07:26 PM   #2 (permalink)
bajamtnbkr's Avatar
You are a true mountain biker now, can you fix my broken spoke? J/K
bajamtnbkr is offline
Dino Brown (12-28-2007), el_d00der1n0 (12-28-2007)
Old 12-28-2007, 07:30 PM   #3 (permalink)
Look Ma - No hands!
ghixon's Avatar
That's something I've always wanted to try but never had the brains to do yet. Let us know how the feel.
ghixon is online now
Old 12-28-2007, 07:31 PM   #4 (permalink)
Sir Smack-Alot
Dino Brown's Avatar
Integradriv3r- How many kids do you have that you DON'T know about
Pugz- For an Asian man he is pretty big
Dino Brown is offline
Old 12-28-2007, 07:32 PM   #5 (permalink)
I'm old hat at spoke replacement. Pick up the replacements, and we'll fix it tomorrow.
My Blog
Old 12-28-2007, 09:58 PM   #6 (permalink)
bjammin's Avatar
good job Brian. It takes guts and patience to build a fine set of hoops.
bjammin is offline
el_d00der1n0 (12-29-2007)
Old 12-28-2007, 09:59 PM   #7 (permalink)
Warrior Society Member
mtnbikej's Avatar
Building them is the fun part........tensioning the spokes on the other hand is a tedious chore.
mtnbikej is online now
Old 12-28-2007, 10:21 PM   #8 (permalink)
dwlink
thebush's Avatar
Nice! Looks good and don't forget to let us know how it rides.
thebush is offline
Old 12-29-2007, 10:37 AM   #9 (permalink)
nappyt's Avatar
Way to go man.
nappyt is offline
Old 12-29-2007, 11:08 AM   #10 (permalink)
dudevf1
dudevf1's Avatar
Thanks for this inspiring task. This is something that I want to do in 2008 as well.
dudevf1 is offline
Old 12-31-2007, 10:44 AM   #11 (permalink)
Originally Posted by OffRoadie View Post
How long did it take you? Did you use a truing stand?
It took about an hour to lace it. Dishing/tensioning and truing took another hour and a half. I don't have it perfect yet.
I have this stand: http://www.performancebike.com/shop/...tegory_ID=4221
My Blog
Old 01-04-2008, 08:25 AM   #12 (permalink)
Default I'm done -- front and back
I got the other rim from Jenson yesterday. I built the rear wheel and finished truing the front. I put it all together and they're on the bike now. Too bad it will be raining all weekend.
The rear wheel was a little more difficult than the front. Zinn's book has you flipping back and forth and I probably drank more than I should have before starting. It looks good to me, and I compared it to an already built wheel.
The spokes were easier to tension on this one. The flanges come out further, and I didn't run out of thread like I did on the front. Dishing it was just as easy as the front. I just flipped it on the stand and got it really close to the same distance hub end to rim on both sides.
For everything, the rear wheel took about 2 hours.
I took pics, but they're at home. I'll post them later.
My Blog
bajamtnbkr (01-04-2008), BrewMaster (01-04-2008), JOx2 (01-04-2008), Red Hot Sloth (01-04-2008)
Old 01-04-2008, 09:02 AM   #13 (permalink)
Au575's Avatar
I just did this, too - felt the stock wheels on the Yeti were too burly for me and made that an excuse to finally build wheels. A couple of free resources that I found helpful are:
http://www.sheldonbrown.com/wheelbuild.html
and
http://www.dtswiss.com/SpokesCalc/Calculator.aspx
Dooder, might I suggest a quick road ride to load up those wheels and then recheck the tension/trueness before heading out on the trails?
Au575 is offline
el_d00der1n0 (01-04-2008), TCB (01-04-2008)
Old 01-04-2008, 09:11 AM   #14 (permalink)
I was going to put around the neighborhood tonight if it's not raining. Next, I'll do an easy trail ride.
It's kinda scary.
and
I found DT's calculator a bit unreliable. You have to make sure they have the measurements right. In the end though, there's room for a little fudging.
My Blog
jeffj (01-07-2008)
Old 01-04-2008, 10:16 AM   #15 (permalink)
Yeti. Turner. Niner.
PacMan's Avatar
Your break-in/test bride should be a Noble shuttle--I'll drive. And believe you me, I'll have the helmet cam!!!!
Less typing...more riding.
PacMan is offline
Old 01-04-2008, 02:43 PM   #16 (permalink)
Good Grasshopper
JOx2's Avatar
Nicely done El d00d!!! you're d00derific!!!!!
JOx2 is offline
Old 01-04-2008, 04:56 PM   #17 (permalink)
Default Back Wheel Pics
My Blog
Old 01-04-2008, 05:28 PM   #18 (permalink)
TCB
TCB's Avatar
Important question, what beer is recommended to drink while building the wheels.
"Keep it singletrack” stay on the trail to avoid widening the trail, on narrow singletrack stop and lean the bike to one side to allow others to pass.
SDMBA
TCB is offline
Old 01-04-2008, 05:30 PM   #19 (permalink)
PacMan's Avatar
Your nipples are red!!
PacMan is offline
Old 01-04-2008, 06:34 PM   #20 (permalink)
