Old 05-09-2008, 12:46 PM   #41 (permalink)
Elisheva's Avatar
Use soft brush for the stick on dirt.
simple green when necessary.
never hose down my bike.
baby wipes work great for a quick wipe down after a ride.
Elisheva is offline
Old 05-09-2008, 01:01 PM   #42 (permalink)
Freeriding is both
G-Ride's Avatar
There is really no need to use Simple Green to clean a bike, and never ever use water, especially from a hose. Simple Green is a degreaser, and it's very easy for it (and water too) to seep into pivots, headsets, BBs, hubs, etc. I've seen plenty of parts ruined this way. Usually I just brush/wipe off excess dirt, then use Windex and a rag since it evaporates quickly and won't dissolve grease or lube. I don't really see a need to degrease drivetrain parts either. I use a cog brush for the cassette and rings, and maybe a little WD40 on a rag to clean the chain (or a toothbrush if needed), then re-lube.
Carpe omnis - seize it all
G-Ride is offline
Old 05-09-2008, 02:51 PM   #43 (permalink)
Expert Beginner
NO GO's Avatar
To clarify, I only use the simple green or Windex (forgot about that) on a rag then wipe the frame down.
Clean the chain and cassette with a brush. Then take them off and clean both in gas. I was shocked at how much dirt and crap came off. Keep in mind I only do this occasionally. Normality is a brush and compressor.
NO GO is offline
Old 05-10-2008, 08:50 PM   #44 (permalink)
I ride really fast to air clean my bikes. I don't clean them because I don't want any bearings getting contaminated with water. I've got 1500+ miles on the same bottom bracket, so I'm sticking with this method. All I do is wipe them down every once in a while. If I go on a muddy ride, I take the entire drivetrain off the bike, and soak it in a bucket of simple green.
92se-r is offline
Lambda_drive (05-10-2008), Seat Sniffer (05-10-2008)
Old 05-13-2008, 12:31 PM   #45 (permalink)
All Access Pass
kbteachme's Avatar
A friend of mine purchased a cheap cleaning brush at Ross and it works well for cleaning those tough spots near the BB, FD and RD.
... with graphics like this how can you not ride - station
kbteachme is offline
Old 05-13-2008, 12:43 PM   #46 (permalink)
And now, we dance.
BobBurnes's Avatar
To clean my bikes, I use a brand of bike cleaner called "Muc-Off". It's available on Amazon.com and, unlike SimpleGreen, won't harm your paint or discolor any of your components. It also doesn't leave a sticky or slippery film.
You can get it in the kit (sponge, cleaner, water remover, and chain cleaner with three brushes) or you can purchase each of the items on their own.
Step 1: Using a hose on mist, water the bike down
Step 2: I spray the Muc-Off all over the bike, especially in the spots on the frame that love to collect dirt or mud.
Step 3: Give it about 60 seconds the mist the bike off again. For the stubborn dirty areas, use a brush.
Step 4: Towel dry off, using a water remover to displace water in allen (hex) bolt faces. Careful with the brakes and pivoting joints of full suspension bike.
Step 5: For the OCD people in the house like me, I use Mother's Gold wax or spray on wax on the frame.
Step 6: Go back out and get 'er dirty.
"I need to learn to ride better."
-Brian Lopes, 2008 Sea Otter
BobBurnes is offline
kbteachme (05-13-2008)
Old 05-13-2008, 01:03 PM   #47 (permalink)
kevinator's Avatar
Originally Posted by tkblazer View Post
i hire midgets to clean my bike
LOL, do you toss them when you're done with them?
Clean rag w/Simple Green and an old toothbrush for chain/gears. If there's chunks then garden hose (low pressure) keeping away from BB and hubs.
Drivetrain gets wiped and lubed after every ride, frames cleaned about every other time.
When I die I want to go peacefully like my grandfather; not yelling and screaming like the passengers in his car....
kevinator is offline
R.I.P. - List your old bikes here! What did you start on? What bikes do you miss? L8 APEKS General Discussion 115 06-30-2008 04:48 PM
My bike story with a little life thrown in. autoduel Introduce Yourself 5 09-11-2007 07:14 PM
The worst Bike Shop Rental Experience...BIKE OUTPOST Fired Yo Momma General Discussion 3 04-24-2007 12:22 PM
Bike Co Sale and Ride Wrecker The Market Place 13 04-22-2007 09:22 PM
Saddles and your junk 0gravity General Discussion 8 04-10-2007 06:00 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82
