Old 12-21-2007, 09:52 AM   #1 (permalink)
Default Setup help: 2006 Zoke 66sl
Found one on E-bay on the cheap, will give it a try on the 2007 RFX. Currently have a 2006 Z1 Light with ETA on there, so it will need to be a better than good fork to take it's place. I know SSINGA has time on one a has always and seemed to like it.
Question is: give me some starting points to set up the air champers. ! am 220 lbs, small hucks...looking for good small bumps compliance keeping the breakdrive under control. It should be here by the time I get back form Sedona.
THX
Old 12-21-2007, 11:04 AM   #2 (permalink)
TURNERob's Avatar
How do you think that fork will be for climbing steep stuff Dean? No travel adjust on it and its a tall fork. I'm not sure you'll be very happy with the small bump compliance on it coming from a coil Zokie. Mine is the '07 with ATA so I don't think the air pressure set up would be the same as the '06 but I'm not sure. I remember seeing some guys on the Turner board trying all kinds of tricks to get rid of the stiction on those forks. Supposedly the '07 was a big improvement as far as stiction is concerned. Sorry I can't help you much with the air pressure settings. A lot of times guys will list their pressure settings on the fork reviews on mtbr. Otherwise I'd search the Turner board also.
TURNERob is offline
Old 12-21-2007, 11:15 AM   #3 (permalink)
It is going to be a second fork, I am keeping the Z1. I am aware of the twisted lowers issues and the resulting stiction. Tscheezy puts a little oil under the wipers to fix that problem and still says it it the best fork he has ever had.
If the experiment does work I am not out much money. With 3 bikes in the stable I can afford to push it more into the downhill range.
2006 Marzocchi 66SL SSinGA The Market Place 4 09-06-2007 05:16 PM
2006 Transition Gran Mal complete, regular size, $1500 kazlx The Market Place 1 08-16-2007 11:17 PM
2006 Trek Remedy 66 mtnbikej The Market Place 7 08-09-2007 10:03 PM
National Trails Day 2006, June 3rd MTBMaven General Discussion 0 05-22-2006 11:21 AM
15% off 2006 Camelbak CalEpic The Market Place 3 04-06-2006 06:14 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106
