Old 12-20-2007, 08:05 AM   #1 (permalink)
cjwally's Avatar
Question Disc Brake - ?
So...I wanted to upgrade to a 185 mm rotor, soo last night I dropped by Da Path to pick up a new mount and rotor. As I cruised home, I was thinking about how much fun it would be to fill up a big glass of Stone IPA and change out my rotor. Sounds good, right? Well, I did poor the glass of beer then everything just didn't work out after that... For some reason, I was unable to loosen the torx screws that hold the rotor on the hub.
Any tips on getting these things off? They are frekin' stuck!
cjwally is offline
bighit8 (12-20-2007)
Old 12-20-2007, 08:10 AM   #2 (permalink)
in auto clubs we say "heat, beat, repeat"
you may need to heat it up to break down the thread locker (only a little heat!), try some penetrating lube and let it sit for a bit, and lastly a little force. with a torx bit installed on your socket extension, give a few light taps. This force may be enough to break down the thread locker bond.
Big Boys ride.....BIG wheels.
Chewyeti is offline
bighit8 (12-20-2007), cjwally (12-20-2007)
Old 12-20-2007, 08:11 AM   #3 (permalink)
Ghetto Swan Lake
Hey Craig,
Yeah, I've actually broken a T-25 socket trying to remove those once. How long is the wrench you're using? I use a beam type torque wrench and that does the job.
Maybe spray some WD40 first? That's what I usually use when trying to remove siezed bolts?
Worse comes to worse if you round out the bolt... You could always file down the sides of the bolt making flat spots on each side and grab it with channel locks to turn the bolt.
Pho'dUp is offline
Old 12-20-2007, 08:13 AM   #4 (permalink)
RIP Gene
DeeZee's Avatar
Default Sounds like
use a high quality torx wrench. i have the park one.
if you wind up rounding them out, you can always cut a slot across the head with a dremel tool and unscrew them with a flat blade screwdriver or chisel.
you have done that before
me too
DeeZee is online now
cjwally (12-20-2007), mechmann (12-20-2007)
Old 12-20-2007, 08:13 AM   #5 (permalink)
Pato's Avatar
Try using a heat gun or a hammer drill/wrench. If you don't have any of those you can try using a plain old hammer and try to "lightly" hammer the screws a bit to break the bond between the screw and the hub.
I'm off on Fridays and weekends. On the DL so, have tools, will travel. Let me know if you need help.
Duc
Pato is offline
allison (12-20-2007), cjwally (12-20-2007), Pho'dUp (12-20-2007)
Old 12-20-2007, 08:13 AM   #6 (permalink)
Bend over
soul rider's Avatar
Wear some heavy duty gloves so you don't shave/cut your knuckles off on the rotor
soul rider is offline
cjwally (12-20-2007), ShinKen (12-20-2007)
Old 12-20-2007, 08:15 AM   #7 (permalink)
me too
We used to have the damnedest times trying to get r/c engine head bolts off.
allison is offline
Old 12-20-2007, 08:17 AM   #8 (permalink)
RIP Gene
DeeZee's Avatar
Default He is right
Originally Posted by Pho'dUp View Post
Hey Craig,
Worse comes to worse if you round out the bolt... You could always file down the sides of the bolt and grab it with channel locks to turn the bolt.
in the long run it will take less time and $$. Lube those suckers up and let them sit. Then you should be able to get them off.
Before installing make sure you use some alcohol or ? and clean everthing up an then apply more thread locker
Old 12-20-2007, 08:20 AM   #9 (permalink)
Pickettt's Avatar
Try using a torx bit on a long ratchet handle or breaker bar. I find it hard to believe a long lever won't break them loose. I wouldn't use a torque wrench for loosening stuck bolts, it may affect it's future accuracy.
Pickettt is offline
cjwally (12-20-2007), Pho'dUp (12-20-2007), SAR_boats (12-20-2007)
Old 12-20-2007, 08:28 AM   #10 (permalink)
As people states above, long ratchet w/ torx bit (sometimes I use an old straight handlebar/pipe inserted into the handle to get more leverage), and try heating up the bolt to loosen up the loctite (some compounds are designed that way).
Cableguy is offline
Old 12-20-2007, 08:45 AM   #11 (permalink)
cjwally's Avatar
Too late, my hands are f'd from trying last night!
cjwally is offline
Old 12-20-2007, 08:47 AM   #12 (permalink)
freerider
socal ridur's Avatar
thats exactly what i had to do to atleast 3 screms everytime i switched rotors just dont cut to deep..i almost did that
downhill, because golf and football only require one ball
Rockinthecasbah
...today was the first day I felt like 7 inches wasn't enough
socal ridur is offline
Old 12-20-2007, 08:47 AM   #13 (permalink)
I would go with double bastard next time. IPA isn't strong enough to help you tear s#it up.
My Blog
allison (12-20-2007), BrewMaster (12-24-2007), cjwally (12-20-2007), Pho'dUp (12-20-2007), SAR_boats (12-20-2007)
Old 12-20-2007, 09:15 AM   #14 (permalink)
nappyt's Avatar
I'm the master of using the wrong tool for the wrong job. I have had that happen a few times. Last time was when PacMan was upgrading to his 8" rotor. I grabbed my drill found a bit smaller then the hole and drilled the damn thing out. If your not careful you can damage the rotor, the hole and the hub. Like I said the wrong tool for the job.
So far I'm 3 for 3 with no fatalities. I was drinking that cheap Karl Strauss Amber Lager from Costco all three times so that might be the secret.
NappyT
My Blog
nappyt is offline
Old 12-20-2007, 09:46 AM   #15 (permalink)
cjwally's Avatar
lol... like i said, buy a high quality park torx wrench. it looks like a T handle wrench, but the one side of the T has the "bolt remover" and the regular side of the wrench is so you don't over-torque during install.
as mentioned before, a pencil torch can help loosen the locktite by liquefying it.
First stop on the way home....Da Path
cjwally is offline
Old 12-20-2007, 10:06 AM   #16 (permalink)
Karnivore
mtbchip's Avatar
I'm sitting here trying to figure out the issue.....
Oh, DOH...... I don't even have them funny bolts with XTR brakes. My rotors are spline mounted (something like that)
Another note, not to start a flame game, but reading in "Dirt Rag" several months ago I saw a quick article about rotor size. The question was does bigger make a difference. I'm sure many of your reading this RIGHT NOW are thinking YOU BET!
But the upshot in the article was..... well, I hate to burst anyones bubble...... but increasing front rotor size make negligable difference on mtbikes.
Don't ask me, I don't have an eng or phyics degree, I just like riding
mtbchip is offline
Old 12-20-2007, 10:14 AM   #17 (permalink)
Bend over
soul rider's Avatar
ah yes double Bastard...
Old 12-20-2007, 10:26 AM   #18 (permalink)
JfromLV Fan Club Prez.
FyrFytrRyn's Avatar
i had this happen along time ago. worse lead to worse and i ended up drilling the thread out of the hub, re-tapping and having to drill the rotors out. pita. id just buy a new wheel.
FyrFytrRyn is offline
Old 12-20-2007, 10:44 AM   #19 (permalink)
Karnivore
mtbchip's Avatar
...(snip) if you are trying to keep up with me, you better have big rotors when you need em.
I would think I would need bigger cranks to keep up...
..... now I'm REAL confused.......
..... ah , I sense a "thread-napping". Lets stay focused!
mtbchip is offline
Old 12-20-2007, 11:04 AM   #20 (permalink)
TKCastle's Avatar
Wow thats cool! All my stripped screw extraction was learned from racing nitro rc trucks. Any set of easy-outs are a must when dealing with small screws in torx and allen heads.
TKCastle is offline
Thread Thread Starter Forum Replies
