#21 (permalink) | |
#23 (permalink) |
Using a big lever as your first option is asking to snap the screw heads off. 1st try breaking the threadlocker by a nice love tap with the hammer while your twisting. 2nd option is the heat. (you'll need to be careful of the seals in the hub) You can get an impact driver if it's really stuck. Repeat the cycle. I doubt penetrating oil will help with threadlocker.
When putting it back together chase the threads with a tap and die to clean then up then use the blue loctite not the red. Bring a growler over if you need help ![]() I used to work on boat engines that lived in saltwater. stuck bolts on a bike are nothing.
#24 (permalink) |
Shrek must be destroyed
bigger rotors dont make you stop faster.
They do a few things- Better Heat dissipation Better Modulation Heat dissipation A larger rotor has more surface area. More surface area exposed to the moving air around it will help keep your brake rotor cooler. Cooler brakes lead to less brake fade (from too much heat). Cooler brakes stop better and dont fade Better modulation. using the formula for tangential velocity (the speed at the edge of the rotor), V = rw where v = tan velociity, r = radius of rotor, w = angular speed. so for the same wheel rotation (same w) the tangential velocuty goesup by a factor of r (or goes up with the increase in radius) so a taller rotor will move through the brake pads alot faster. you will wear out pads faster due to this increased speed, but you have a larger braking moment, which will enable you to modulate the brakes better, AA
autoduel (12-21-2007),
bighit8 (12-20-2007),
BrewMaster (12-24-2007),
cjwally (12-21-2007),
el_d00der1n0 (12-20-2007),
nappyt (12-20-2007),
Pato (12-20-2007),
SAR_boats (12-20-2007)
#25 (permalink) |
Uh, I just think bigger rotors look cool.
Seriously tho. does the tangental arc equation take into account (what seems like) the larger leverage that a larger rotor has in relation to a wheel than a smaller rotor? If you think of the contact area of the tire with the dirt as the load and the axle as the fulcrum and the area where the pad contacts the rotor as the force then it would stand to reason that a larger rotor would have a larger leverage ratio than a smaller rotor. I am not sure about this so any of you brainiacs feel free to chime in. Oh and as to the original topic: Using a torque wrench as a breaker bar will blow the calibration. Use heat and and a SMALL impact wrench to get the bolts off (ideally an electric one b/c they are easily modulated and put out less torque than air powered) Basically- Listen to CalEpic |
#26 (permalink) | |
Welcome to California. Now shut up and start climbing! |
#27 (permalink) |
Hey Craig,
You might try an impact driver, if the bolts are not to rounded you can hammer in the right size Allen head and just heat it up a bit. I think cheweti covered most of it. Worse comes to worse I have some screw extractors!
Roger: You guys should join us next Sunday. It would be nice to have another screamer CHEWYETI: Heat, Beat, Repeat! ![]()
#28 (permalink) |
By the way the IPA was good, thanks. If I had known I would have tried to help you out.
#30 (permalink) |
Increased size adds better modulation in my opinion but you get alot more noise on regualr moutend 203's, centerlocked 185's you should be ok , if your a weight wennie then bigger is not better. Me and chewy kept smokin are 6" rotors so we went to 203's which was too big chewy is down to 185's and love them after he got his caliper issiues out of the way. I'm back to 8's on my big bike and 6's on my Dj/4x bike its all about what feels right.
#33 (permalink) | |
drive monkey, drive!
#34 (permalink) |
Dumb question here, when replacing a rotor, are there other options besides TORX head screws? I hate those things and I would rather use hex screws, but not sure if that is an option. Thoughts?
#35 (permalink) |
TORX bolts are far superior to conventional hex bolts because they will allow far more torque before stripping the heads than hex bolts.
#36 (permalink) |
Easy way to heat a screw to help coax it out without heating up the entire component is to hold a hot soldering iron to the screw/bolt for 30 seconds or so.
BrewMaster (12-27-2007)
#38 (permalink) | |
Were you using the screwdriver type before? A good 3/8 or 1/4 socket set is nice to have. Over my years as a mechanic I estimate over 7000$ in assorted sockets alone.
Rockinthecasbah (12-25-2007)
