Old 12-18-2007, 08:54 PM   #1 (permalink)
Tom Brady Look A Like
MTBMaven's Avatar
Default Niner Rear D Cable & Heal
For those with hardtail Niners, do you catch your heal on the rear derailleur cable?
I've pretty much finished my MCR build but can't ride right now due to an injury. Looking at the rear cable routing I notice how the rear dérailleur cable cuts straight across the curved seat stay. It seems like my heal is going to catch the cable while riding from time to time.
If this becomes a problem I think I can run full cable housing past the top tube and use a cable tie so the housing follows the curved seat stay.
You must be the change you wish to see in the world Mahatma Gandhi
Border? I have never seen one. But I have heard they exist in the minds of some people. Thor Heyerdahl
All steel stable: '08 DeSalvo - '07 Niner MCR9 - '89 Specialized Sirrus fixed/free
MTBMaven is offline
Old 12-18-2007, 09:00 PM   #2 (permalink)
Default We need
pictures
Old 12-18-2007, 09:35 PM   #3 (permalink)
dudevf1
dudevf1's Avatar
My rear cable runs under the top tube and then down the seat stay on my 29er. I have never had a problem catching the cable.
dudevf1 is offline
Old 12-18-2007, 09:41 PM   #4 (permalink)
MTBMaven's Avatar
Pics of the cable routing issue in question:
[SIZE=1](Note my lizard flare) [/SIZE]
Pic of the almost completed build. I still need to get the fork cut.
MTBMaven is offline
Old 12-18-2007, 09:49 PM   #5 (permalink)
It looks pretty high to catch your heal on it.
Old 12-18-2007, 09:52 PM   #6 (permalink)
P. W. R.
J_Sims's Avatar
my hard tail niner has no cable... ONE9 and save yourself the headaches...
Big Thanks to :::
J_Sims is offline
foofighter (12-18-2007)
Old 12-19-2007, 12:29 AM   #7 (permalink)
Cool you should be able to shift with your foot.
BrewMaster (12-19-2007)
Old 12-19-2007, 07:05 AM   #8 (permalink)
MTBMaven's Avatar
That's kinda what I'm worried about.
MTBMaven is offline
Old 12-19-2007, 07:29 AM   #9 (permalink)
MTBMaven's Avatar
i would say your primary option would be to go full housing in that section and zip tie it to the stay.
I would tend to agree. Full housing in the rear is the only way to deal with this. Once I get out there with it I will be able to determine if it will be a problem. I have extra housing so doing the work is no big deal. I wanted to check if this was an existing issue for others. It doesn't sound like it, which is cool.
MTBMaven is offline
Old 12-19-2007, 07:44 AM   #10 (permalink)
dudevf1
dudevf1's Avatar
My 29er hardtail has housing over the cable where it travels from the top tube to the seat stay. On the seat stay the cable is exposed but it has guids that it is secured through.
dudevf1 is offline
Old 12-19-2007, 07:47 AM   #11 (permalink)
you could try to find an eyelet or something to add to the frame in the middle of the stay to pull the cable over, but in doing so you will introduce the likelihood of shifting issues with wear/stretch/movement.
In that area I would run full housing, zip tie it to the stay and then wrap. Did the same thing on my old Santa Cruz Bullit. That area gets a bunch of dirt and will gunk-up your cables
Old 12-19-2007, 08:59 AM   #12 (permalink)
Default Edit
sorry I was looking at the pic wrong and thought the cable was located on the chain stay. I have never seen that part of the frame wrapped-up like that
IMO you have nothing to worry about. I ran gears on my SIR9 for awhile and never had a problem. Oh and I wear size 13 shoes
Old 12-19-2007, 09:39 AM   #13 (permalink)
MTBMaven's Avatar
Had that part wrapped on my 575 and the tape got pretty banged up over the years from some chain slap and falls.
I wrapped the non-drive side chain stay as well on this bike. This is my first painted from in years and I want it to stay looking perty. I actually find of like the way it looks. In the end it doesn't really matter much one way or the other. It may come off down the road.
MTBMaven is offline
DeeZee (12-19-2007)
Old 12-19-2007, 09:44 AM   #14 (permalink)
Default Don't
worry about the cable you are good.
I am the same way with my frames. Picked up a sheet of 3M clear tape and put it on all of the cable rub areas
Old 12-19-2007, 10:16 AM   #15 (permalink)
Default How much weight
BTW...
my Niner has the cables going down the DT and under the BB so the RD cable goes under the CS. that arrangement has it's own set of problems.
do you save by not running full length housing
Cable housing? RustyIron The Workshop 24 11-13-2007 09:01 PM
Rear Derailleur Protector, Pros/Cons TwoLeggedHorse General Discussion 8 11-02-2007 01:49 PM
rear der. cable destruction?? lukewiens The Workshop 3 10-30-2007 10:09 PM
Niner One 9 vs Niner Sir 9 cjwally General Discussion 31 07-02-2007 11:24 AM
Rear hub on it's way out???? ECOdork The Workshop 6 10-03-2005 09:30 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106
