Ive gotten most of my build done and have run cable housing for both Derails. but now as I run the cable and lock down the rear(x-9, with shift at 9), and start to do a test shift I notice the cable is dragging the housing. here is the senario:
1. No chain or cassette is in play(meaning Im installing the cable without the chain and Cassette in place) 2. I cut the cable housing but did not shave the ends and clean out the hole(per sheldon Brown's write up) 3. my first time!!!!! running my own cables. I will try to post up pics of where it drags tonight once I get home!!! I really want to learn how to do this so please don't tell me to take it to a shop, even though I will once I reach my wits end!!! TIA Thai |
Do Work (12-19-2007)
spit on it
Do Work (12-19-2007),
Red Hot Sloth (12-18-2007)
cable is dragging the housing -- Not sure what you mean by this. If the housing stops at the cable/frame stops, then you shouldn't have any drag. Also, you might want to try lubing the housing (although some thinks this attracts dirt).
.8down (12-18-2007)
Donny
sounds like the housing was cut a bit too short?? hard to say - fun stuff eh? Once you get the whole cable/housing thing down, it'll shift like butter. Which reminds me....time to replace all mine as well.
God made man, but he used the monkey to do it. DEVO |
I hope you are not correct, this would mean I would have to get extra housing!!!! |
First of all you can't take shortcuts or you'll just end up swearing on every ride because your bike shifts like crap.
1 - You need to make sure your cuts are clean and you opened up the hole the cable slides through. You can't skip this. 2 - How are you planning on adjusting your derailleurs without your chain/cassette on? I know you don't want to hear this but if you cut the housing too short and you are having other issues throw it in the trash and start over. Bulk housing is cheap. It's really not that difficult. It sounds like you have the Sheldon Brown book. Look through the directions completely before you start. Then follow those directions step by step. If it's still a problem maybe bring a six-pack to your LBS and they may let you watch them. C
.8down (12-18-2007)
Tom Brady Look A Like
If I understand things correctly, you need to have the cassette and chain installed at this point. You don't necessarily need to have them installed when cutting the cables but if you try to run through the gears without the cassette and chain installed you will get what I think you are experiencing. Before you go through the trouble of re-cutting things install the cassette and chain. Follow Sheldon's advice for chain length.
If you do have to re-cable things I highly recommend Dura Ace cables. I only run the cables and have for the past 3 years. I read years ago in some study by the Germans that Dura Ace cables stretch the least of any cable on the market, save some Jagwire cable model I could never find. Dura Ace cables are easy to find and only a few dollars more.
You must be the change you wish to see in the world Mahatma Gandhi Border? I have never seen one. But I have heard they exist in the minds of some people. Thor Heyerdahl All steel stable: '08 DeSalvo - '07 Niner MCR9 - '89 Specialized Sirrus fixed/free |
.8down (12-18-2007)
#15 (permalink) | ||
these are the stops in the rear triangle: ![]() these are teh stops on the top tube, notice the allow the housing to move back. ![]() finally this is what happens when I pull the triggger: ![]() Quote:
ya I think I will take everything off and recheck all my cuts, I did use the proper cable/housing cutter by Park tools, but I do think some cleaning of the cut areas, and opening of the holes as well as putting the wheelset, chain and cassette into play...thanks everyone for your constructive critic of my job...I really do want to learn how to do all this correctly, and without some hands on guidance I expected to run into trouble spots.
#18 (permalink) |
It's all good. Make sure the r der. isn't "stuck", have all the gear on the bike when you run the cable/housing, clean cuts, open housing ends, new ferrules(not pinched), no binds or sharp bends in housing, couple beers keeps the cussing down, step away for a few minutes, come back with a fresh mind and eyes.
There is only a couple things that can cause what your experiencing. You'll get it right. ![]() |
Dirty Boo (12-20-2007)
As people already wrote above, I think you need to shift test while the cassette and everything else is in place. And make sure there aren't any frayed cable strands causing problems. Lastly, try lubing the housing. Graphite powder is supposed to be the way to go, but I have used regular lube with success.
