Old 12-14-2007, 06:58 PM   #1 (permalink)
Live Free, Ride Hard
Jman's Avatar
Default Looking to build...
I am a serious newb to building bikes, in fact if it wasn't for this forum I might not even be thinking of doing it. I have an 03 Bullit frame just sitting and collecting dust so right now I'm looking for a fork on ebay. First question is this, I keep seeing a width of 1 1/8" being shown. I'm assuing that this is the headtube width. Also is the standard width...I believe the 1.5 is the more abnormal width right?
The second question is more of which is better question. I've found a Marzochi AM 2 and a Rockshox Domain for around what I have budgeted for a fork. Both are 07. Any ideas. I'd be setting the bike up for more of freeride thang. Just curious if either of these would work. I had a Psylo on it before I blew that fork out and replaced it with a Tora when I swapped parts to the Chameleon.
Thanks in advance for any guidance you might be able to provide.
jmansdirtloverparadise.blogspot.com
'07 Heckler
'07 Chameleon
'06 Specialized Allez
Jman is offline
Old 12-14-2007, 07:28 PM   #2 (permalink)
DAN THE MAN
capnsavem's Avatar
i dont have any info to offer you, since i have no experience with that frame, but i wish you good luck on your build.
FoShizzle: lactic acid is ghey. if you dont ride you will not have issues with it
capnsavem is offline
Jman (12-14-2007)
Old 12-14-2007, 07:32 PM   #3 (permalink)
^needs to ride more
davidB's Avatar
1 1/8" is the standard size, headsets will be in this size as well. But when in doubt, pull out the ruller. While you're at it, measure the bottom bracket width so you'll know that width. That'll help when putting your crankset in, spacers may be needed.
davidB is offline
Old 12-14-2007, 07:43 PM   #4 (permalink)
Jman's Avatar
Thanks for confirming that. One more question that just popped into my head. How much steerer tube should you ideally be looking for in a used fork. Obviously I need to measure the headtube but how much above and (if needed) below should I try for? Thanks
'07 Heckler
'07 Chameleon
Jman is offline
Old 12-14-2007, 07:48 PM   #5 (permalink)
genusmtbkr5's Avatar
You need enough for the headset stack and the stem. the stem should grab at least 3/4 of steerer. Then if you want to put spacers, add that. The longer the better, you can always cut it.
Gene"GuidesNewWarriors"
http://www.sharemtb.com/
genusmtbkr5 is offline
New Bike Build Flat Broke The Workshop 15 08-23-2007 04:45 PM
Another new bike build... Flat Broke The Workshop 10 08-21-2007 11:11 AM
Suggestions for a build anonomous09 The Workshop 12 06-24-2007 08:06 PM
5 Spot build finally completed.... dhshuttlemonkey General Discussion 8 11-10-2006 12:21 AM
