Old 12-10-2007, 10:33 PM   #1 (permalink)
dwlink
thebush's Avatar
Default E13 DRS users?
I'm going to be picking up an E13 DRS to use with my M770 crank and was wondering if anyone here uses or has used a DRS.
1.) Was the additional friction from the DRS noticeable and did it affect your climbing?
2.) Did the front derailleur require more maintenance then usual?
3.) What kind of chain lube since mineral oil based lube shouldn't be used (bye bye my beloved Boeshield T9)? How did you determine chain length?
thebush is offline
Old 12-10-2007, 11:10 PM   #2 (permalink)
TCB
TCB's Avatar
I just put a Blackspire Stinger Dual Ring Tensioner on my RFX with M770 cranks, it works great uphill, back peddling and I have not dropped a chain, it cost $24 at BB, vary easy to install, you will need a Bashguard, you can get one for about $30, still under the $100 + you will spend on the E13, I know Mouse Jockey has been using the Blackspire and a few other brands, he should be able to give you some good advice, throw him a PM or maybe he will chime in
Why can’t you use mineral oil based lubes on Chain Guides or is that just with the E13.
TCB is offline
thebush (12-11-2007)
Old 12-11-2007, 05:54 AM   #3 (permalink)
Pato's Avatar
I'm usually the last one up the hill anyways so no real difference to me.
The only other difference is that you adjust the high limiter screw to restrict shifting beyond the middle ring.
I use White Lightning so no change for me. Determining chain length is the same as without the guide. Just use the middle ring instead of the big ring when measuring. Wrap the chain around the middle ring and big cog without going through any of the derailleurs then add two links (or one inner link plus the quicklink).
Hope this helps.
Pato is offline
Old 12-11-2007, 07:41 AM   #4 (permalink)
I 2nd the Blackspire Stinger. Even without a top guide I've never dropped the chain.
When measuring your chain, be sure to run it through any guide.
Old 12-11-2007, 08:03 AM   #5 (permalink)
on a routine expedition
Marshall Willanholly's Avatar
I never noticed it.
Nope. Remember to run it in the same position it would be in with a big ring installed.
My favorite is Dumonde Tech.
For chain length, I shift into the big-big combo (and, as Cal Epic mentioned, run it through the guide), deflate the main air chamber or remove the coil from the rear shock, and compress the suspension to make sure bottoming my suspension won't rip the rear derailleur off.
Old 12-11-2007, 08:10 AM   #6 (permalink)
Just another slacker.
Sprockethead's Avatar
Hmm, I'm wondering if that's why I'm killing my cassettes. I measured the chain without running it through the guide, then put the Blackspire on. Since then, I've bent 2 cassettes.
Sprockethead is offline
Old 12-11-2007, 08:57 AM   #7 (permalink)
dwlink
thebush's Avatar
Thanks everyone for the help and info! It's greatly appreciated Plenty of good advice and info that I didn't even consider.
I was actually checking out Blackspires products earlier...hmm decisions.
thebush is offline
Stan’s sealer users DeeZee The Workshop 11 10-28-2007 08:07 AM
Questions for Garmin GPS users Waldo The Workshop 25 09-12-2007 11:20 PM
Garmin Edge users and Daylight Savings Abui General Discussion 2 03-10-2007 08:56 AM
Gravity Dropper Users - Question mdbradigan General Discussion 9 01-31-2007 09:53 AM
users with most "thanks" in 2006 LBmtb General Discussion 6 01-04-2007 10:48 AM
