Old 12-10-2007, 03:44 PM   #1 (permalink)
DAN THE MAN
capnsavem's Avatar
Default hanging my bike...
hey all
i want to hang my bike in the corner of my terrace (due to lack of space).
i'm looking to hang it with just one big hook, removing the front tire and hanging it from the triangle.
now... i'm picturing a large hook with a rubber coating to avoid scratching.
since i've never hung anything besides a small picture on a bulletin board, is there anyone who can recommend a specific hook they may use?
im at work right now, so i thought id ask before i head over to home depot after work.
thanks
-Danny
FoShizzle: lactic acid is ghey. if you dont ride you will not have issues with it
capnsavem is offline
Old 12-10-2007, 03:51 PM   #2 (permalink)
We have a couple of our bikes hanging in the garage from hooks. We actually have them hung by the nose of the seats. My bikes use the larger black hooks (fairly thick black coating), and my wife's are hung by the yellow (you guessed it..yellow coating) hooks. I have no idea what brand they are, but the hooks have served their purpose well for several years, and are very inexpensive.
Red Hot Sloth is offline
capnsavem (12-10-2007), Dirty Boo (12-20-2007)
Old 12-10-2007, 03:51 PM   #3 (permalink)
Originally Posted by capnsavem View Post
hey all
thanks
-Danny
I couldn't find a hook with high enough weight rating at Home Depot. I got some from Ace. They're big enough for a large MTB tire. They'll hold 40lbs max, so if it's bigger than that, you'll need 2. Oh, and the rating changes depending on how you hang it (ceiling or wall).
You'll need a drill and some bits to pre-drill the hole.
Make sure you hit the middle of the stud or joist. I used very small nails to find the sides and shot the drillbit right in the middle.
Test that puppy before you put your pride and joy on it!
My Blog
Old 12-10-2007, 03:55 PM   #4 (permalink)
Or Not Enough
TooManyTacos's Avatar
I use a few of the Leonardo bike wall hooks by Delta Designs:
I asked a friend to help me locate the wall studs and we just drilled the hooks in there.
TooManyTacos is offline
Old 12-10-2007, 03:58 PM   #5 (permalink)
bajamtnbkr's Avatar
If you hung up the bike upside down should be worried about any oil leak from the fork????
bajamtnbkr is offline
Old 12-10-2007, 03:59 PM   #6 (permalink)
I know we saw some at the Container Store. Someone already mentioned it is the Leonardo model. $20
Old 12-10-2007, 04:00 PM   #7 (permalink)
DAN THE MAN
capnsavem's Avatar
thanks guys
the reason im looking to hang it from the triangle is because there's not enough space to have it hanging horizontally.
i'll make sure i check the load cap. for the hooks, never thought of that.
however, that Leonardo one might work for what i need... hmmm
Old 12-10-2007, 04:02 PM   #8 (permalink)
Or Not Enough
I got the Leonardos from Performace for $14.99 each, including the tray for the rear tire:
http://www.performancebike.com/shop/...TOKEN=99848415
Old 12-10-2007, 05:25 PM   #9 (permalink)
DAN THE MAN
capnsavem's Avatar
thanks TMT... i'll walk into the local Performance to see if they have 'em... looks like they're out of stock online.
think so?
maybe if you have an issue with the seals.
bajamtnbkr (12-10-2007)
Old 12-10-2007, 05:37 PM   #10 (permalink)
think so?
Some forks can have internal issues. My Tora has instructions on getting it back by flipping the lockout a few times.
My Blog
Old 12-10-2007, 05:43 PM   #11 (permalink)
I wouldn't really worry about the forks. If anything it will help lubricate the seals. I would be more worried about hanging it upside down and an air bubble in the disc brake system causing a problem. Keep the master cylinder higher than the caliper and you should be fine. I've transported bikes upside down before and never had a problem but I've heard about it. Urban legend?
bajamtnbkr (12-10-2007), capnsavem (12-10-2007), guero (12-11-2007)
Old 12-10-2007, 06:18 PM   #12 (permalink)
DAN THE MAN
capnsavem's Avatar
i'm running mech discs so thats one less thing to worry about right now
but definitely something to think about when i upgrade to some strokers.
Old 12-10-2007, 11:22 PM   #13 (permalink)
92se-r's Avatar
I just found out my Pike leaks from the Motion Control damper top when hung upside down. Now I don't know how to store my bike. My seals dont leak at all and it doesn't leak from the Motion Control thingy when I'm riding. Only when upside down.
92se-r is offline
Old 12-11-2007, 12:02 AM   #14 (permalink)
Baker.
guero's Avatar
this urban legend came to life one morning for me with my shimano xt disc brakes on my superlight. for some reason i had it upside down, i think i was adjusting the front caliper and when i was done, i turned it back over after mounting the wheel and i pulled the lever and it went all the way to the handlebar. after pumping it many, many times it eventually went back to normal...the rear brake was fine though..
tkblazer: pump and dump.
guero is offline
Old 12-11-2007, 01:26 AM   #15 (permalink)
bonedaddy
bobzrag's Avatar
I've got mine hanging from the rafters in the garage - two big hooks from Home Despot, some rope and a pulley - had it there the last two years and no problems
"They've done studies, you know. 60% of the time it works, every time." Brian Fontana
bobzrag is online now
capnsavem (12-12-2007), DirtRider (12-11-2007)
Old 12-11-2007, 10:49 PM   #16 (permalink)
RustyIron's Avatar
I made a couple hooks out of pieces of all-thread, about 5/8" diameter. I bent them into a desirable shape and jammed a piece of hose over each.
RustyIron is offline
bobzrag (12-11-2007), capnsavem (12-12-2007)
Old 12-11-2007, 10:53 PM   #17 (permalink)
P. W. R.
J_Sims's Avatar
I hang all of my bikes from the ceiling and they do hang from the wheels so they are updide down... Never had a challeng with any of the forks and I use rubber bands on the brake levers to keep pressure in the system and have yet to have any issues...
Big Thanks to :::
J_Sims is offline
bajamtnbkr (12-12-2007), capnsavem (12-12-2007)
Old 12-12-2007, 07:26 PM   #18 (permalink)
DAN THE MAN
capnsavem's Avatar
GOOD INFO GUYS.
thanks
Old 12-12-2007, 07:45 PM   #19 (permalink)
Cowgirl's Avatar
There are companies that don't recommend hanging their forks upside down. Check with the fork company you have on your bike before you hang it....
Cowgirl is offline
bajamtnbkr (12-12-2007), capnsavem (12-13-2007)
You know you're a mountain biker when.... OMR The Pub 34 05-27-2008 04:02 PM
Need your advice, Boss won't let me store my bike inside building. Fired Yo Momma General Discussion 45 04-11-2008 06:29 PM
Anyone ever look at the similar bikes tried on mtbr? RacinJason General Discussion 78 11-25-2007 09:49 PM
My bike story with a little life thrown in. autoduel Introduce Yourself 5 09-11-2007 08:14 PM
Hanging your bike</
