Tom Brady Look A Like
OMFG I have been battling to mount a Bontrager Dry X 29 tire on a Stan Arch rim for nearly 30 minutes. I was able to mount it without a tube after a great dealing of wrestling. However I cannot get it to mount with a tube.
Is there some trick? Is this something unique to 29" tires, Stan Archs, or these Bontrager tires? If I were on a ride I think I would walk out rather than go through this amount of work to fix the problem.
You must be the change you wish to see in the world Mahatma Gandhi Border? I have never seen one. But I have heard they exist in the minds of some people. Thor Heyerdahl All steel stable: '08 DeSalvo - '07 Niner MCR9 - '89 Specialized Sirrus fixed/free |
#2 (permalink) | |
What do you do on the trail then? No soapy water and generally no beer.
I have a set of levers for downhill tires I break out when the going gets tough.
My experience with 29" tires is that they are usually too loose. I have rolled Exi's off my Mavic 719 twice. I have used Exi's, Rampages, and Ignitors all went on by hand. Dean
Peanut butta jelly
I think once they're mounted it'll be a little easier next time. I read somewhere, there's a few of the 9er tires that will fit easier, just ever so slightly larger. Can't remember the models though. Search emptybeer.
If quizzes are quizzical, what are tests? “Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body—but rather a skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, ‘Wow, what a ride!’ ” —anon. |
I just ordered valve stems, yellow tape, and sealant from NoTubes. I had to get more tape because I destroyed the tape The Path installed trying to get my tires on last night. I was able to mount the tire without a tube but not with the tube. I also picked up some extra wide levers and 29" tubes.
Unfortunately Stan recommends mounting the wheel with a tube for at least 30 minutes to set the tape before running tubeless. So no matter what I have to mount the tire with a tube in there at least once. ![]() Let's hope I can now mount a friggin' tire. You'd thing after biking this long I could put a tire on a rim. ![]()
Hors Catégorie
Just be sure the bead is in what Stan calls the "drop center".
Did you watch the install movie? |
The rim tape The Path used seems pretty thin. It's blue and much thinner than the traditional cloth rim tape.
#19 (permalink) | |
B |
#20 (permalink) | |
Can you use this Blue Specialized tape for tubeless applications? Meaning not use the Stan's tape? Bet you a beer it is all made by 3M ![]() |
| 29" Tires, Pace Carbon Fork, SS stuff | donkey | The Market Place | 6 | 12-01-2007 02:38 PM |
| slightly used tires but still awsome tires | DasBrink | The Market Place | 9 | 08-30-2007 10:29 AM |
| Tires and Size | Jordansrealm | The Workshop | 18 | 08-23-2006 01:41 PM |
| Tires / Stans | Pain Freak | General Discussion | 3 | 03-19-2006 07:36 PM |
