Old 12-07-2007, 11:37 PM   #1 (permalink)
Sir Smack-Alot
Dino Brown's Avatar
Default Single speeder's: Help Needed...
A friend is considering converting one of his bikes into a single speed. He does not want to spend a lot of money.
1) Any opinions (good/bad) regarding the FORTE Conversion Kit? For $20, it seems to come with everything one would need! http://www.performancebike.com/shop/...slisearch=true
2) I have seen kits ranging from $20- $125.
3) Any information (i.e. chains, spacers, tensioner) would be most appreciated!
Forte' Single Speed Conversion Kit
Integradriv3r- How many kids do you have that you DON'T know about
Pugz- For an Asian man he is pretty big
Dino Brown is offline
Old 12-07-2007, 11:57 PM   #2 (permalink)
Yeti. Turner. Niner.
PacMan's Avatar
I used the Forte kit when I built my first SS on a frame with verticle drop-outs. It works great. It is truly a bargain. Now that I have a frame with horizontal drop-outs, I don't use the tensioner, but I'm still using the 20 tooth cog and the spacers.
For $20, you CAN NOT go wrong.
Less typing...more riding.
PacMan is offline
Dino Brown (12-08-2007)
Old 12-08-2007, 12:02 AM   #3 (permalink)
genusmtbkr5's Avatar
It's a very inexpensive way to build a SS, if he likes it he can always upgrade to a better tensioner like Surly and better cogs like Chris King
Gene"GuidesNewWarriors"
http://www.sharemtb.com/
genusmtbkr5 is offline
Dino Brown (12-08-2007), mtnbikerfred (12-08-2007)
Old 12-08-2007, 12:13 AM   #4 (permalink)
Sir Smack-Alot
Dino Brown's Avatar
Gracias!
Old 12-08-2007, 08:00 AM   #5 (permalink)
Hors Catégorie
Abui's Avatar
The cogs have a thin base so an Aluminum freehub will wear fast.
Get a cheap-strong BMX chain.
Abui is online now
Old 12-08-2007, 08:22 AM   #6 (permalink)
I made a Taco this big!
Yep. If he has a nice rear hub (Al body) those chainrings will slice into it like buttah. Get a surly cog.
Pho'dUp is offline
Old 12-08-2007, 08:32 AM   #7 (permalink)
Dino,
I have a brand new Surly Singulator that I'll sell for $25 ($37 at Jenson). I may have a new Surly 18T cog, but I'm not sure if I still have that - I need to look.
For spacers, I've read where people use cut PVC pipe.
Lee
Old 12-08-2007, 08:55 AM   #8 (permalink)
Sir Smack-Alot
Dino Brown's Avatar
Thanks Lee! Will forward the info to my friend!
Old 12-08-2007, 09:00 AM   #9 (permalink)
Peanut butta jelly
Dino, ALL ss'ers need help.
2wheel_lee (12-08-2007), andy aka rut (12-08-2007), bajamtnbkr (12-10-2007), BandMan (12-10-2007), bjammin (12-09-2007), BrewMaster (12-08-2007), chauvinist_youth (12-09-2007), Dino Brown (12-08-2007), genusmtbkr5 (12-08-2007), J_Sims (12-10-2007), KonaDupee (12-09-2007), LBmtb (12-10-2007), PacMan (12-09-2007), thebush (12-10-2007), Waldo (12-09-2007)
Old 12-09-2007, 06:21 PM   #10 (permalink)
The G is for Gear
1FG rider's Avatar
1FG rider is offline
Old 12-09-2007, 10:05 PM   #11 (permalink)
I'd rather be climbing...
KonaDupee's Avatar
Hmn....Dino says he has a "friend" that is considering converting to SS...
No need to be ashamed, Mr. Mayor. Come over to the SS side!
All the fun, twice the pain & a fraction of the mechanical headaches!
Climbing *is* its own reward!
It's obvious I'm not a weight-weenie; I ride a Kona!
KonaDupee is offline
allison (12-10-2007), chauvinist_youth (12-09-2007), Dino Brown (12-09-2007), Pain Freak (12-09-2007), Waldo (12-10-2007)
Old 12-09-2007, 10:18 PM   #12 (permalink)
Sir Smack-Alot
Dino Brown's Avatar
Andy Rut, Gene, Hugh, 2 Wheel Lee, Singletrakk, Shinken (and a host of others) should back me up on this one...... a singles speed (IS) going to happen!!!!
Been talking about it for quite some time. Need to finish a FR bike first!
First test on that single speed.... BIG RED!!!! Will Ya' Join me?
Konadupee and Bandman After Conquering Big Red!
genusmtbkr5 (12-09-2007), KonaDupee (12-10-2007), Waldo (12-10-2007)
Old 12-09-2007, 11:18 PM   #13 (permalink)
bjammin's Avatar
Where is "BigRed"? After nearly barfing a lung at the Sladnas ride, I'd like to regurgitate the other lung on that hill!
Welcome to California. Now shut up and start climbing!
bjammin is offline
Old 12-09-2007, 11:28 PM   #14 (permalink)
Sir Smack-Alot
Dino Brown's Avatar
Peter's Canyon! Not the "most fun" you can have on two wheels! Steep! Legs burn! Even if you are doing well, there always seem to be a few spots that make you spin your rear tire. Not fun at all.
Directions: http://www.goodtime.net/tus/lotus001.htm
Old 12-10-2007, 06:45 AM   #15 (permalink)
KonaDupee's Avatar
Just say when & where!
Old 12-10-2007, 07:53 AM   #16 (permalink)
Sir Smack-Alot
Dino Brown's Avatar
When? A few days AFTER I build the single speed. (Spring?)
Where? You know where! I'll meet you at the bottom of the hill.
Old 12-10-2007, 08:22 AM   #17 (permalink)
bikeaholic
bikeadict's Avatar
+1 on the PVC spacers if you want to get into it cheap. And I'd advice a non spring tensioner (i.e. DMR sts chain tensioner)
http://www.universalcycles.com/shopp...ls.php?id=9754
or a Rennen Rollenlager if you really wanna spend some doe.
http://www.downcycles.com/store/renn...ger-p-325.html
I just think the bolt ons work better than anything spring acutated. It allows you to set your own tension and you don't have to worry about a spring failing and leaving you high and dry.
Also +1 on wide based cogs (i.e. surly, endless, chris king, niner, boone (if you've got the $$$), etc) Maybe once you (or your friend) figures out which tooth count you'll run.
bikeadict is offline
Dino Brown (12-10-2007)
Old 12-10-2007, 08:04 PM   #18 (permalink)
I have 29"
BandMan's Avatar
Default Yo Dino!!!
BandMan is offline
Dino Brown (12-10-2007), PacMan (12-10-2007)
Old 12-10-2007, 08:47 PM   #19 (permalink)
New is the beggining
El Prieto's Avatar
Dino,
The best way not to spend money on a single speed conversion kit is to set your bike in one gear, and if after that your friend can deal with the burning then spend the twenty.. my opinion...........
[SIGPIC][/SIGPIC]
El Prieto is offline
