Old 12-03-2007, 08:26 AM   #1 (permalink)
northshore's Avatar
Default Correct mounting position of a Fox Float R
During the last Fully ride, 2WheelLee and I were wondering why the Fox Float R was inverted on my I.H. MKIII. I noticed all the MKIII '07 models are inverted and all the MKIII '08 models are not. Since it's inverted, will it adversly effect the rebound and compression? Would you recommend to remount the shock?
Hawaiian Island Creations
Ride it: dw-link.com/reasons
northshore is offline
Old 12-03-2007, 09:01 AM   #2 (permalink)
good question, because i've notice similar differences on some ellsworth shock mounting as well.
www.coverageispersonal.com
foofighter is offline
northshore (12-03-2007)
Old 12-03-2007, 09:02 AM   #3 (permalink)
It doesn't matter which way it's mounted. My guess is there is a clearance problem with the shock mounted in the normal position or a problem accessing the schraeder valve. If you decide to switch it, let all the air out of the shock and cycle the suspension all the way to make sure nothing makes contact with the shock.
foofighter (12-03-2007), northshore (12-03-2007)
Old 12-03-2007, 09:18 AM   #4 (permalink)
uno, dos, tres bubbs
Skeeter's Avatar
yeah, typically its a clearance issue. I know in off-road truck suspension sometimes the tires would rub if the body of the shock was on the bottom so we had to mount the bodies on top. No measurable effect we could find.
Skeeter is offline
Old 12-03-2007, 09:20 AM   #5 (permalink)
northshore's Avatar
Would be interesting to invert my Konis on my track car for giggles.
Old 12-03-2007, 10:35 AM   #6 (permalink)
Shrek must be destroyed
also.. think unsprung weight.
If the shock is 'inverted' then the heavy part of the shock is mounted (fixed) to the frame, and the lighter (moving) part is mounted to the moving trailing arm or rocker.
Suspension is a lot more responsive when it weighs less (takes more energy to put mass into motion)
F = ma (newton was a smart guy)
Takes more force to move your suspension when it weighs more....
-Aaron or Chewy
08 VOODOO Canzo 29er
08 Santa Cruz NOMAD
Chewyeti is offline
BrewMaster (12-03-2007), Dino Brown (02-13-2008), northshore (12-03-2007), thephat (02-13-2008)
Old 12-03-2007, 11:04 AM   #7 (permalink)
northshore's Avatar
If the shock is 'inverted' then the heavy part of the shock is mounted to the frame, and the lighter part is mounted to the moving trailing arm or rocker.
Yup! Went with lighter wheels/brake combo on my track car.
Old 12-03-2007, 11:19 AM   #8 (permalink)
as did we! LOL
going from cast iron 2 pistons to late model aluminum monoblock 4 pots.... w/ a custom adapter for axial mount to radial mount applications.
-Aaron or Chewy
08 Santa Cruz NOMAD
Chewyeti is offline
northshore (02-13-2008)
Old 02-13-2008, 03:13 PM   #9 (permalink)
northshore's Avatar
Sorry about bumping an old thread but I got around to sending an e-mail to Iron Horse about the inverted Fox Float R on my horse and I literally received a response in 46 minutes!! Here is the response:
Ken,
Thanks for the e-mail. The rear shock on your bike is mounted that way for clearance issues. If you were to move the air valve to the top then the upper link would contact, and probably break, the air valve. For 2008 they are mounted right side up because Fox moved the air valve to exit at a 45 degree angle, thus clearing the upper link. If you have any other questions let me know.
Regards,
Carl E.
carle@worldwidecyclesupply.com
Customer Service/Warranty
1-800-645-5477 ext:214
2006 Fox float RLC fork SAR_boats The Market Place 0 09-06-2007 09:30 AM
mmmm, a delicious Vanilla Float pollu_sean The Workshop 17 08-20-2007 10:58 PM
Newb: Mounting Time ATAC Cleats? slideonmtns The Workshop 1 08-07-2007 09:08 PM
