#101 (permalink) |
Ok folks, I am getting ready to order some parts for my 3x Cree XR-E Q5 light build. I know Cree has come out with the R2 binned LEDs which are a tad brighter, but I am not going to spend the extra money on those. I am looking to buy most of my parts from Cutter in Australia. If anyone wants to buy parts with me to save on shipping, let me know.
Here's what I am buying from Cutter: - 3 Cree XR-E Q5 LEDs on a star board ($9.02 USD each) - 3 Ledil Square Lenses, two 7ー and one 6ー, ($3.44 USD each) I will also be order a driver from Task LED; - 1 bFlex driver ($30 + $5 flat shipping from Sunnyvale, CA) I already have the 14.8 V / 4400 mAh battery and charger I need.
天ery few are meant for a life of notoriety, yet all of us are meant for a life of significance." Erwin McManus, Wide Awake |
#103 (permalink) | ||
SoCalMTBubbs
So my light rebuild had taken a while with no communication. I was pretty sure that meant bad news. I finally received this late last week: This is the situation with your bike light- We received the new cells, and installed them in your light. We tried to charge the assembly, with your charger, but got nothing. We took the new pack apart, and found ALL the new cells were fried! Couldn't figure out why. So we sent for more cells. We installed the 2nd batch of cells. Before we tried charging this pack, we took a reading on your charger. Your charger is bad, and is not putting anything out. So we charged the pack on our charger. We then installed the new pack and tried the light. Nothing! We took this pack apart, and found that all these cells were fried also. Now we are pissed. We started doing the CSI thing on your light, and found that the wiring harness is bad. The 2 wires were broke, and shorted together. This probably fried your charger, as well as 10 of our new cells. We have already burnt up 50.00 worth of cells, and don't want to try any more. So needless to say, your light has not been rebuilt. We have all the parts for you, and can show you the harness. I suggest you buy a complete new assembly, this isn't worth the money it would cost to repair. F! Oh well. The light lived a good life. FWIW - West Coast Battery Builders were great about the whole thing. I would not hesitate to recommend them. Really super folks. Nonetheless, I am still without a light! I'm going to be jumping on the homemade trail pretty quick. I'd love to use my existing trailrat housing/battery case if possible. I seem to remember an empty beer thread about someone doing this, but I can't find it. I have an old Maglite and may go that route too. |
BrewMaster (12-27-2007)
#104 (permalink) |
sounds crappy chris, at least you have an option to build your own now.. i'm going to pick up the aluminum pieces tomorrow am
#105 (permalink) | |
#109 (permalink) |
A little dab will do me
Ok, I've bucked up and have some stuff on the way from Cutter. Went a little different route.
Shipping Method: Economy Air -------------------------- Product ID: cut651 Product Name: Cree XR-E Power Leds Quantity: 4 Unit Price: $7.00 > LED Mounted on Single MCPCB : Star MCPCB (+$1.25) > XR-E Flux and Cool to Neutral Tint Bin Selection : R2 Flux (WH Tint) Cold White (+$4.90) > XLamp Price Break : 1-5 -------------------------- Product ID: cut688 Product Name: 10200 Carclo Lens Cree XR-E Quantity: 2 Unit Price: $7.95 > Price Break : 1-25 -------------------------- Product ID: cut687 Product Name: 10199 Carclo Lens Cree XR-E Quantity: 2 Unit Price: $7.95 > Price Break : 1-25 |
BrewMaster (01-03-2008),
Dino Brown (01-02-2008)
#111 (permalink) | |
#112 (permalink) | |
That way I could just use 2 lights at a lower setting when climbing if I wanted to. As long as I can get around the loop that's all the battery I'll need. |
#113 (permalink) |
Could you use the same battery to drive 4 and 2 LED configurations using the bFlex driver? I thought the voltage for 4 LEDs would be too high for 2 LEDs and as far as I understand it the bFlex only regulates current, not output voltage. I could be wrong on this though.
#116 (permalink) |
I'll have to looking to it a little more. I'll dig into it this weekend. Maybe I'll end up with buckpuck type of delios.
But no matter what I plan to get all of that stuff ordered on Monday. Drivers, connectors, cabling and such. as far as weight goes I bet it will be lighter then what I use now. My old nightrider digital deal with the 2 halogen bulbs weighs in at 2.25 pounds. I also have an old Night rider digital headtrip and don't know the weight on it. I'll bring it to work on Monday and toss it on the scale. |
#117 (permalink) |
Dave (or anyone else), if you order anything from Future Electronics, please let me know. If need to replace the lenses on my green light, but the lenses are about $3 and shipping and handling is $10. I'd like to share the shipping with someone if possible. I need 4 of these lenses. Thanks.
#120 (permalink) | |
To run the 6 chip one, you could use a switcher boost circuit, which does not really effect run time because these can be over 90% efficient. Your analogy about the candle does not hold true. You could run a standard say 14.4V battery with a boost dc-dc converter and then run to a constant current supply.
Also, according to the datasheet, it is not 1100 lumens. It is only 504 lumens. IMO, not worth the effort for the voltage. Current K2 w/ TFFC LED's are up to 180-200 lumens PER LED at 1A. Quote:
Flat Broke (01-10-2008)
