#41 (permalink) | ||
天ery few are meant for a life of notoriety, yet all of us are meant for a life of significance." Erwin McManus, Wide Awake |
#42 (permalink) |
Life behind bars
Deans... definitely Deans... they won't come apart on you while you're mashing 40+ on those night downhill sessions... right Dino? And thanks for the mention of Ford electronics. I have been going to them since I was nine, great people. Just my .02
Something witty and intelligent goes here...
COLEKO (12-01-2007),
Dino Brown (12-01-2007)
#43 (permalink) | |
None of these low voltage detectors are specific for any sort of battery. They say they are meant for Lithium Ion batteries, because they are usually what are used in 3.3V applications. That is why they are only rated up to 6V. These would not work for your batteries.
What I would recommend is use a LM317 or equivalent linear regulator for a regulated 5V output or something. Then use a LM139 comparator powered off this regulated output. Then use a voltage divider to set your reference voltage so that when your battery voltage dips below a certain voltage, it trips the comparator and drives a MOSFET to turn on a buzzer. That is what I am going to do on my personal light I'm building. There is no way you will even notice a little LED that turns on when your battery voltage is low while you are riding. I'm going to have a 100db piezo buzzer that I can manually override so I don't have to listen to it for the rest of the ride, but I know that I've got about 30-45 minutes of battery life left. It only adds about 10 small parts that you could easily package. Quote:
BrewMaster (12-03-2007),
Dino Brown (12-02-2007),
Fired Yo Momma (12-03-2007),
OffRoadie (12-02-2007)
#45 (permalink) |
SoCalMTBubbs
#46 (permalink) | ||
http://www.dealextreme.com/details.dx/sku.1302 http://www.dealextreme.com/details.dx/sku.2394 Perhaps I will change LEDs on my helmet mount light that I will build soon.
#47 (permalink) |
yup i posted that scar thread in my other thread about the lupines...
i like this design as well, might have to copy it ![]() http://forums.mtbr.com/showthread.php?t=248012
#48 (permalink) |
Client 9
First of all cold job BrewM for your lights look good. You have inspired me, really!
Anyways you can also get parts at Mar Vac Electronics in Costa Mesa or Ford Electronics, I think they are in Anaheim or Fullerton.
And the hangovers hurt more than they used to And corn bread and ice tea took the place of pills and 80 proof And it seems like none of us do the things quite like we used to do And nobody wants to get high on the town And all my rowdy friends have settled down -Hank Williams Jr. |
#49 (permalink) |
Nice find Nam. This would make a nice housing:
http://myfwyc.org/bikeled/ConstructionSteps.html Chewyeti, do you have a band saw or other cutting implements? We could make some of these as helmet mounts. They look pretty sweet.
#51 (permalink) |
Just thought I'd throw this out there for the STR DIY'ers. I have access to a PCB cutter at work and could make custom PCB's if you need them. I can only do double sidded copper boards with unplatted via holes. I would just need a hand drawn sketch or a .dxf file to make them. I have a bunch of different materials but the most common are .047 and .062 polyimide.
Dino Brown (12-03-2007),
OffRoadie (12-04-2007),
OTHRIDER (12-04-2007)
#52 (permalink) | |
At this rate, we may have STR lights on sale before we get another batch of jerseys made!
#53 (permalink) | |
sam, that design is so simple yet seems to work really well for the original designer..
#54 (permalink) | |
A little dab will do me
My shop is in Placentia. I've been thinking about doing a run of lights for awhile now. Now with STJunky with the PC board hook up I bet we could really make something nice. |
#55 (permalink) |
i'll post up when i am about to make an order on led's and crap, if people are interested they can PM me when the time comes to save on shipping.
#56 (permalink) | |
I think my next light is going to have 3 Cree LEDs on it. I will definitely use a wired buckpuck next time instead of trying to solder it all in such a small space. This guy's DIY site is pretty thorough. I may have to copy his design with my own modifications.
#57 (permalink) |
what about making the housings round kinda like these?
http://www.ayup.com.au/colours.html Could do doubles, tripples and quads. Maybe a tripple (flood-spot-flood) on the bars with a double (spot - spot) on the lid. Maybe mount the batts and buckpuck in a waterbottle and have some small switches on the bar. |
BrewMaster (12-04-2007)
