Old 11-21-2007, 11:14 PM   #1 (permalink)
ah buh bye now
Default Avid Juicy 5 Question: Whats that noise?
I'm breaking in a new bike with Avid Juicy 5's, and they're making this wierd warbling sound. Is that normal?
Gone for good. PEACE.
Evil Chocula is offline
Old 11-21-2007, 11:29 PM   #2 (permalink)
call me Angry.
Mudman's Avatar
haha wth is warbling?
I've always had a strange noise coming from my brakes, but people have assured me it normal although my rotors are not warped, and the caliper is properly aligned.
Pissing the world off- One person at a time....
Chuck Norris sleeps with a pillow under his gun.
Mudman is offline
Old 11-21-2007, 11:32 PM   #3 (permalink)
i got game.
guero's Avatar
the warble is somewhat 'normal' choc. i had it with my juicy 5's. do some searching on the forums here. steppie posted a pretty good reply in regards to it. i didnt do too much to make it go away, but it eventually did over time.
tkblazer: pump and dump.
guero is offline
Old 11-22-2007, 12:13 AM   #4 (permalink)
speckledtrout's Avatar
my juicy 5's on my juliana warbled like a turkey something fierce! i ended up having to replace the pads and the calipers. the guys at the bike shop said that they'd had problems with some of the brakes and avid admitted that there were problems. at least, that's what i was told. i haven't had any problems with my juicy 7's on the stumpjumper until recently, but it typically only happens after i've been riding for awhile and/or i ride on the brakes too hard.
speckledtrout is offline
Old 11-22-2007, 02:39 AM   #5 (permalink)
XC DBL DD
Chicks Who Rip's Avatar
I have avid juicy 5's on my epic and they scream like a stuck pig! I have been assured by many that this seems to be the norm with these brakes but it drives me crazy! I just turn up the volume on my ipod and try to ignore it
Chicks Who Rip is offline
Old 11-22-2007, 06:14 AM   #6 (permalink)
same noise comes from Linda's Juicy 5s, but mostly from the rear caliper. I too have been assured that this is normal, though it annoys the hell out of me when I am riding next to her. I think a pad adjustment feature like that of the Juicy 7s would fix this.
Old 11-22-2007, 07:32 AM   #7 (permalink)
my friggin pads are screaming too when i was bleeding out my brakes and got some onto my pads... now i think i have to get new pads.
www.coverageispersonal.com
foofighter is offline
Old 11-22-2007, 08:24 AM   #8 (permalink)
Look Ma - No hands!
ghixon's Avatar
I'm not positive on this, but there was a problem with the Avid Paragon rotors a few years ago. Something about the alignment being goofed up or something. I changed over to the Clean Sweep Rotors and never had a problem with the turkey warbling again.
ghixon is offline
Old 11-22-2007, 08:24 AM   #9 (permalink)
Default I see a bunch of different symptoms in this thread
Avid makes a few different rotor shapes. The clean sweep rotors (round not wavy) run the quitest.
The juicy 5s come stock with metalic pads. If you switch to organic, you will have less overheating, and less squeel in genereal. They organic pads make less noise in general. Some really chronic brake noise starts with overheating the brake. You will see discoloration on the rotor if this is the case.
On accasion one piston sticks, and will not push or retract evenly. This can cause noise while applying the brake. I think that this is the "known issue" mentioned earlier in this thread. I have known Avid brakes to have this defect, but it is rare. This problem is not limited to Avid. I have seen other brands have this issue. In fact, Sram is quicker than most companys to just take responsibilty right or wrong.
Contamination can definetely cause noise. Sometimes you can even pick contaminants up in a mud puddle. more often it is misdirected chain lube, or brake fluid. Once contaminated, you will pretty much have to replace the pads, and in some cases the rotor too.
A little "warbling" under specific conditions is pretty std. Sqeeling like a stuck pig all of the time is not.
thephat is offline
Rob (11-22-2007)
Old 11-22-2007, 08:28 AM   #10 (permalink)
Don't worry the sound will go away after Thanksgiving.
It sometimes helps to take the pads out and sand them down a bit.
Pain Freak (11-22-2007), thebush (11-22-2007)
Old 11-22-2007, 08:28 AM   #11 (permalink)
Code Blue's Avatar
Default ...
yes...........yes you do. There are all kinds of things that can make brakes [FONT='Times New Roman'][FONT=Verdana][SIZE=2]Squeal. One thing can lead to another...[/SIZE][/FONT][/FONT]
[FONT='Times New Roman'][FONT=Verdana][/FONT][/FONT]
[FONT='Times New Roman'][FONT=Verdana][SIZE=2]For best results.......Clean pads / rotors and proper [FONT='Times New Roman'][FONT=Verdana][SIZE=2]Alignment should all be performed at the same time[/SIZE][/FONT] [/FONT][/SIZE][/FONT][/FONT]
As it seems that this thread may be headed for the usuall as of late STR Down hill spiral JSims
Code Blue is offline
foofighter (11-22-2007)
Old 11-22-2007, 09:38 AM   #12 (permalink)
Do the organic pads stop as well as the metallic?
My Blog
Old 11-22-2007, 09:47 AM   #13 (permalink)
Better but they wear out quicker.
Old 11-22-2007, 09:50 AM   #14 (permalink)
At 18 bucks, that's not a big deal. How much faster? Do you leave the metallic in the inboard spot?
My Blog
Old 11-22-2007, 10:52 AM   #15 (permalink)
Peanut butta jelly
I was having an issue with squealing, but baked the pads and no more problems since then. 450 degrees for 20 minutes seemed to work for me.
foofighter (11-22-2007), thebush (11-22-2007)
Old 11-22-2007, 10:58 AM   #16 (permalink)
were these new or old pads?
Old 11-22-2007, 11:09 AM   #17 (permalink)
Do you baste them with anything? What about the giblets? What do you do with them?
My Blog
Old 11-22-2007, 01:28 PM   #18 (permalink)
Pain Freak: thanks for the tip, i pulled out both the front and rear pads and popped them into the family toaster oven baked with love for 20 mins at 450 and popped them back into the calipers and viola...solved the noise. PLUS, for some reason (mind you the pads were cool) my front brake levers are super stiff now...makes me want to rebleed my rears
Avid Juicy Bleed Tips Code Blue The Workshop 13 11-14-2007 06:20 PM
Avid Juicy 7 issue... brand new Chewyeti The Workshop 12 10-26-2007 08:44 AM
07 Avid Juicy 5 brakes, 203mm rotors Marshall Willanholly The Market Place 15 10-18-2007 02:32 PM
Avid Juicy 7 w/ upgrades SSinGA The Market Place 3 09-07-2007 03:37 PM
Avid Juicy 5 Jordansrealm The Workshop 13 07-31-2007 12:41 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
