When it's time, you'll know.
2wheel_lee (11-18-2007),
BrewMaster (11-21-2007),
genusmtbkr5 (11-18-2007),
JOx2 (11-18-2007),
Pain Freak (11-18-2007),
SAR_boats (11-18-2007)
As Padre said.
Either when the lever action feels mushy, or something else isn't right. Although, ideally, systems using DOT brake fluid should be bled every couple years or so. Because of the pistons sticking in the calipers, I recently had to bleed my oldest set of Hayes Mags - 7 or 8 years after first bleeding them (I wanted to find out how long they would go without maintenance).
JOx2 (11-18-2007)
Unless you squeezed the lever while the wheel was out causing the pistons to pop out and spew fluid everywhere. But in that case, see Padre's post.
JOx2 (11-18-2007)
I've squeezed the lever with the rotor/wheel out... was able to push the pistons back out with a flathead screwdriver. No bleed neccessary.
The only time I've ever bled any of our 6 sets of hydros, is on a new set of Juicy Ultimates. They "didn't feel right." A bleed later, all is well. I just knew. |
JOx2 (11-18-2007)
#10 (permalink) | |
Squeeze the lever a few times with the wheel and pads removed and tell me what happens. ![]()
Car Magnet
Don't do this JoJo!!!!!
JOx2 (11-19-2007)
Good Grasshopper
common sense dictates something like a spew of fluid.
Climbing, You Know You Want To. |
2wheel_lee (11-19-2007)
| Bleeding Hayes Brakes | project_d | The Workshop | 10 | 10-22-2007 10:16 PM |
| Hayes Brake Rotors & Pads | project_d | The Workshop | 10 | 10-17-2007 08:40 PM |
| Check your brake cables | UR2KLOS | General Discussion | 15 | 09-06-2007 11:28 PM |
| Brake lever pin missing | Paul000 | The Workshop | 4 | 08-07-2007 11:09 AM |
| Brake levers | scorns | General Discussion | 6 | 10-31-2006 09:43 PM |
