Shrek must be destroyed
I destroyed 2 bearings where the rear triangle meets the suspension rocker.
Balls ejected and destroyed the bearing spacer.......causing massive play. lame design, shoulda used bigger bearings. Aaron
I didn't know K2 was still in the bicycle business. Can you go back to the bike shop where you purchased the bike?
Measure your bearings, and go here: http://www.enduroforkseals.com/id169.html And read the bottom here: http://www.enduroforkseals.com/id55.html
Chewyeti (11-18-2007)
K2 is owned by :looks around: Iron Horse
They were bought out about five years ago. Their customer service went from great to crap. (at least as far as warranty is concerned) I wouldn't expect them to have many parts on hand either. But, give them a try. Just don't get your hopes too high. |
Try this: mikel@worldwidecyclesupply.com He set me up with a rebuild kit for an 03 Tirade as well as a new Hangar
i emailed the place i purchased from. No respinse yet.
I busted out my calipers and measured the old bearing race as best as i could. (have to remove it from the triangle first to accurately measure) im gonna try that enduro bearing place! nice site! you all rock! the engineer in me said, bronze bushing on a lathe with a spiral grease groove and a zirk fitting LOL (like we use on porsches) support the load better... http://www.elephantracing.com/images...ounddelete.gif
found the k2 .pdf that specced the bearing size.
bought some upgraded ones from enduro. Mike L is trying to get me the bearing spacer. You guys rock! Aaron
2wheel_lee (11-19-2007)
Mike L found me 2 bearings, and a spacer.
Put em in the mail ala freebie. What a guy! Thanks for the leads guys!
Bike Parts for Christmas
Here's what I ended up using for a bearing press if you decide to do it yourself.
![]() Get a long threaded rod w/ appropriate nuts and washers for both ends. Use appropriately sized sockets to push against the bearing. That black thing is leftover steerer tube. You'll just need something large enough so that the bearing can push through. |
BrewMaster (11-20-2007)
#12 (permalink) | |
#13 (permalink) | |
![]() I just happen to own a Chumba or two. But, yes, they use arbor presses with some machined bits at Chumba to press in/out their bearings. |
BrewMaster (11-21-2007)
the correct response should have been... "no but i stayed at a Holiday Inn Express" ![]()
DAN THE MAN
hehe
FoShizzle: lactic acid is ghey. if you dont ride you will not have issues with it |
foofighter (11-20-2007)
| Avid/Sram customer service? | Chewyeti | General Discussion | 1 | 10-21-2007 04:46 PM |
| Jenson USA seeks customer service superstars! | jchristopher | The Market Place | 7 | 04-18-2007 06:46 AM |
| Kick ass service. | Gabriel Zink | The Workshop | 6 | 04-15-2007 09:27 AM |
| Garmin Customer Service | granny ring | General Discussion | 7 | 02-06-2007 11:55 AM |
| Customer Service, what customer service? | i am dino | General Discussion | 6 | 09-08-2005 04:38 PM |
