Bike Whisperer
Use anything heavier than a screwdriver; jack handle, deep socket on an extension The intension is to transfer the kinetic energy with minimal loss. You need to make sure it bites on the edge of the cup before you hammer. Take your time and switch sides so you don't ovalize the cups. If you cant follow this logic just take it to a shop or get a bigger hammer.
Well, I'm usually all in favor of the do-it-yourselfer, but if you're having difficulties getting the headset off, I'm sure you'll run into problems installing it onto the new frame.
Take the new and old frames to your favorite shop, and toss them a few bucks to do the swap for you. You may save yourself a lot of coin in the long run.
Bike Whisperer
I don't think I would be using steel to beat out anything aluminum. I always have the shop press in my headset.
Pain Freak (11-17-2007)
Team Fearless Descender
[FONT=Century Gothic][SIZE=1]ITEM # RT-1[/SIZE][/FONT] [SIZE=1][FONT=Century Gothic]Park Head Cup Remover[/FONT][/SIZE][FONT=Century Gothic][SIZE=1] [/SIZE][/FONT][FONT=Century Gothic][SIZE=1]The Park Tool Head Cup Remover makes headset cup removal easy. The tool is pulled through the frame until the flared ends snap in behind the cup. A blow on the tool head removes the cup. Fits 1”, 1-1/8” and 1-1/4” headsets. Strong, heat treated alloy steel with nickel finish.[/SIZE][/FONT] |
I always use a small peice of pipe to knock it out. But a big flat head will do just fine, dont be afraid to hit it, just work the tool around to headset in small moves to work it out. Putting one in at home is a different matter, I made a press out of a long bolt and washers from Home Depot, or you can tap the cups in with a hamer, put the frame on a peice of wood (The steerer tube) and put a cup in and tap it with a hammer and wood. I have used a 2x4 and it works fine.
tattoos are trendy |
Take a piece of pvc pipe and split the end with hacksaw/bandsaw. Shove something into the end to flare it out. Insert it backwards into the head tube and hammer it back out with the edges against the inside of the cups.
Basically works just like the park tool.
Amon Amarth (11-19-2007),
El Salt (11-17-2007)
dudevf1
Since you plan on using the headset again you should get the tool and insert and hammer. You will also need a press tool to put the headset on another frame, I wouldn't just use my hands and squeeze. Check the bearings when you get it off.
| STR headset caps | SAR_boats | The Market Place | 26 | 11-12-2007 12:08 PM |
| Headset tools | .8down | The Workshop | 30 | 11-09-2007 08:48 AM |
| Seat post, Headset, F Derailer, brakes, QR seat clamp | Neccros | The Market Place | 4 | 09-10-2007 03:58 PM |
| HeadseT Squick BS? | ShinKen | The Workshop | 20 | 08-22-2007 09:51 AM |
| Help! Is there a trick to removing the headset shim?! | L8 APEKS | The Workshop | 1 | 04-23-2006 10:06 PM |
