Old 11-14-2007, 10:40 AM   #1 (permalink)
^needs to ride more
davidB's Avatar
Default drilling out cable stops
one of the very last steps in finishing my new build is figuring out how I want to run full housing on the derailleur cables
last night I zip tied everything down and cut things accordingly and now i'm stuck between busting out a dremel to do this
http://forums.mtbr.com/showthread.php?t=130062
or to buy 7 of these for about $50
neither of which seem ideal, but I'm leaning more towards drilling out the frame as that'll look better, but my only dremel experience comes from last night and cutting the cable housing with a cutting wheel.
drilling out the 7 cable stops doesn't seem *that* hard, but I tend to not take things slowly sometimes when working.
what to do? what to do?
davidB is online now
Old 11-14-2007, 10:43 AM   #2 (permalink)
Code Blue's Avatar
Default Put the drill away
if your frame is still under warranty and breakes
Also think about resale value
As it seems that this thread may be headed for the usuall as of late STR Down hill spiral JSims
Code Blue is offline
Old 11-14-2007, 10:49 AM   #3 (permalink)
If you don't feel confident drilling out the stops, I'd bet a local shop would do it for you for a nominal fee.
Old 11-14-2007, 10:54 AM   #4 (permalink)
TURNERob's Avatar
I don't think there is any risk of the frame breaking. I've done it before on my old Foes FXR and it was easy. If your frame is brand new I'd probably stray away from doing it. Running full length housing is more appropriate if we lived where the trails were muddy all the time but here in so cal it really isn't worth the trouble.
TURNERob is offline
Old 11-14-2007, 10:56 AM   #5 (permalink)
Warrior Society Member
mtnbikej's Avatar
I usually drill a hole through the side of the cable stop. This allows me to run a ziptie through it to hold down the cable or brake. This does nothing structural to the frame.
mtnbikej is offline
Old 11-14-2007, 11:03 AM   #6 (permalink)
Collette's Avatar
Use these. They simply stick-on to the frame. No drilling required.
http://www.jensonusa.com/store/product/CA401Z02-Jagwire+Stick+On+Cableline+Guide+3+Pack.aspx
Collette is offline
Old 11-14-2007, 11:06 AM   #7 (permalink)
Code Blue's Avatar
Default Not saying
it will break the frame but I doubt the manufact would warranty a frame that has been "modified".
TURNERob (11-14-2007)
Old 11-14-2007, 11:08 AM   #8 (permalink)
TURNERob's Avatar
gotcha, misread what you said
TURNERob is offline
Old 11-14-2007, 11:41 AM   #9 (permalink)
^needs to ride more
davidB's Avatar
never occured to me that shops do this. is this something they all do?
I will be in the tustin area tomorrow morning
Old 11-14-2007, 11:55 AM   #10 (permalink)
Beer! How did you know?
LoisMustDie's Avatar
I drilled out the stops on my Giant Reign; I did not use a Dremel, though. I selected a regular metal drill bit and it went through the soft aluminum like a hot knife through butter. Each stop took me 5 minutes of prep (to ensure everything was lined up and taped off to prevent dings) and about 1 second of drilling (no heat). Be very careful laterally because the stops are very soft.
I would stay away from any drilling process that produces any heat, the way a Dremel might.
It is an easy job, though, and the stops are not a structural element on your bike --- no frame integrity issues.
[FONT=Arial][/FONT]
The result? Clean cables that stay clean and shift like butter.
LoisMustDie is offline
Pho'dUp (11-21-2007)
Old 11-14-2007, 11:59 AM   #11 (permalink)
^needs to ride more
davidB's Avatar
so you went at it with a regular drill? I'm more comfortable with that but working on something so small with a large drill seems a little awkward.
Old 11-14-2007, 12:04 PM   #12 (permalink)
A little dab will do me
spookydave's Avatar
if you are close to the 57/91 bring it by. I have a small air powered drill that would get right in there.
Big bikes are good for your soul.
spookydave is offline
Old 11-14-2007, 12:46 PM   #13 (permalink)
Suck on these
uzziboy's Avatar
I have these on my bike and they work great, PLEASE FOR THE LOVE OF GOD DO NOT DRILL OUT YOUR CABLE STOPS!!! OR HAVE A PROFESSIONAL DO IT BECAUSE IF YOU GO TO DEEP OR STRAY OFF THE HOLE YOU COULD GO INTO FRAME
Why ask why, does it really matter????????
uzziboy is offline
Old 11-14-2007, 12:49 PM   #14 (permalink)
theclayster's Avatar
i also picked me up a pair of those at Jensons...work great!
theclayster is offline
Old 11-14-2007, 12:54 PM   #15 (permalink)
^needs to ride more
davidB's Avatar
any pics? getting 7 at $8 each or so seems a little more expensive than i'd like
Old 11-14-2007, 12:57 PM   #16 (permalink)
i don't have any right now with me...but i can post some later
Old 11-14-2007, 01:09 PM   #17 (permalink)
sure --- no problems. It's so soft it's like grading cheese!
Old 11-14-2007, 01:20 PM   #18 (permalink)
I still say let a pro do it or use those straps from Jenson. No need to spend $50 to mount cables.
Old 11-16-2007, 08:18 PM   #19 (permalink)
92se-r's Avatar
I disagree about not needing it in California. Full cable housings actually lowered cable resistance for me. Definitely worth the hassle.
Also, have a "professional" do it? ROFL. The monkeys at most bike shops don't even know you can run full housing. I've had more than one tell me my der. won't work right. LOL. The only reason they are "professionals" is because they work on bikes for a living. Doesn't mean they are better than you or I.
92se-r is online now
Old 11-16-2007, 09:17 PM   #20 (permalink)
^needs to ride more
davidB's Avatar
I ended up drilling out the stops like pictured above. Easy as cake. Mine came out looking way better than that guys in the thread I linked. I was using the 4mm housing I got from the path which means the holes weren't as big as I'd initially thought. I used a dremel with the largest bit I had available and just made the hole. I later ended up using a drill and a bit that was just smaller than 4mm and went real slow. Frame wasn't under warranty so it was a no brainer
Cable housing? RustyIron The Workshop 24 11-13-2007 09:01 PM
rear der. cable destruction?? lukewiens The Workshop 3 10-30-2007 10:09 PM
Cable disc brakes. sandblast The Workshop 22 09-11-2007 02:26 PM
Got cable rub? I have a solution. i am dino General Discussion 8 08-29-2005 08:49 AM
