#41 (permalink) | |
Epic Builder
Tips - Compressed air to install/uninstall grips - If you're past were you think the bolt should have tightened but isn't, don't continue unless you have time & patience to burn - Only repair what IS broken, otherwise you will find many more troubles and repairs required and not so required |
#42 (permalink) |
Peanut butta jelly
Do you work for me?
If quizzes are quizzical, what are tests? “Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body—but rather a skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, ‘Wow, what a ride!’ ” —anon. |
#43 (permalink) |
l'homme plus
I get more hurt working on my bike than riding it. Think chain rings and brake rotors and then think of knuckles. And, because I insist on working on my bike out of the stand (even though I own a really nice one), my back ends up in a shambles. What a maroon!
Downhill Web Kook Git sum! |
#44 (permalink) |
When frustrated, or pissed off, a few properly placed cuss words often help.
"If you want to go fast, go alone. If you want to go far, go together". - African Proverb ThinkFast's GeoLadders Dashboard |
SAR_boats (11-09-2007)
#48 (permalink) |
Tighten and tighten and tighten till it gets loose, then another quarter turn.
![]() When rebuilding a RS fork, when the manual says cover the thing with a towel, do it. Or you will have oil on your ceiling dripping all over the place and you will look like you just got out of a really bad porn movie. Terrin |
BrewMaster (11-09-2007)
#50 (permalink) |
Same here. Most of my work clothes have some small spot, stain, etc. from coming home from work, seeing my bike in the stand, and deciding to clean the drivetrain.
"Nothing compares to the simple pleasures of a bike ride." - J.F.K |
#51 (permalink) |
ali'i hua
another that might have been covered: when removing a stubborn pedal on the drive side, drape something thick over the drive train- why?
because knuckles + force required to remove said stubborn pedal + chain rings = you donating blood to your bike and your bike donating grease to you. oh wait- does that constitute a "bond" with your bike by swapping fluids ![]() ![]() ![]() |
#52 (permalink) | |
slowSSer (11-09-2007)
#53 (permalink) | |
ali'i hua
#54 (permalink) |
here's a new one, don't ask me how i know....
when trimming down cable housing for a new bike, make sure you pull all the cable out before making the cut ![]()
#55 (permalink) |
I've learned that it is a good thing that most people can't work on their own stuff......because that is where I come in.
Really the only bad thing I can think of that I've done is when I was drilling out cable stops to run full housing that you should tape off the frame around the cable stop to avoid......uhhhh, you know. ![]() |
#56 (permalink) | |
packing big white b@lls
if so...where??? and if not...still planning or killed. thanks
TURNERob (11-09-2007)
#57 (permalink) | |
Kid A (11-09-2007)
#58 (permalink) |
a) Better to wait and do the upgrade Sunday afternoon with a beer than Friday midnight before a morning ride.
b) Not going well? stop, stare at it & think before grabbing the BFH. That's when you find the things like the bad cable housing end. c) Cheap Tricks (could be a whole new thread): 1. No stand? Loop of rope or webbing from an overhead beam. Around the seat to raise the rear wheel. Around the stem to raise the front wheel. Wedge the opposite wheel against something solid. Works for pretty much all adjustments, but not for things where you need the BFH. 2. No chain whip? Plumber's strap wrench is great at 1/2 the price. Even cheaper in a pinch -- jam the cassette teeth in a soft pine 2x4. but you still gotta buy the freewheel wrench. 3. Can't afford lock-ons? Put the grips on with contact cement -- solid! Take 'em right off with a squirt of brake cleaner. 4. Headset press? A really big C-clamp & two blocks of wood, done carefully. |
#60 (permalink) |
Suck on these
nothing like wrenching at 1 am just put new goodrich brake lines on. the only time i take my bike to the shop is to have my wheels fixed and soon i will learn to that. the best advice i can give is take your time!!!! if it takes two days to fix a chain so be it, watch how everything comes apart do it a few times and it will become second nature eventually
Why ask why, does it really matter???????? |
