#21 (permalink) |
I have seen a lot of friends install the headset with a block of wood and a rubber mallet. In college I built my own press at the hardware store.
There have been a lot of posts where people have f'ed up the head tube because of improper installation, making the frame unusable. I'd recommend dropping the cash. The tool should last forever. The Park HS removal tool is too cheap and effective not to have in the arsenal. paz afuera |
#22 (permalink) |
[FONT=Times New Roman][SIZE=3]Is always best but $150 is a lot of $$. You could pay a shop to do it 15 times before you reach your break-even point.[/SIZE][/FONT]
[FONT=Times New Roman][/FONT] [FONT=Times New Roman][SIZE=3]Here is my "poor man’s" method:[/SIZE][/FONT] [FONT=Times New Roman][/FONT] [FONT=Times New Roman][SIZE=3]Removal[/SIZE][/FONT] [FONT=Times New Roman][/FONT] [SIZE=3][FONT=Times New Roman]Go to Lowe’s Hope Depot etc.. and get the largest wooden dowel that will fit inside the cups / HS. Cut it to size and tap the dowel with a hammer as it is rotated around the edge of the cup. [/FONT][/SIZE] [FONT=Times New Roman][/FONT] [FONT=Times New Roman][SIZE=3]Installation [/SIZE][/FONT] [FONT=Times New Roman][/FONT] [FONT=Times New Roman][SIZE=3]The problem here is that some HT (new frames) have not been faced at the factory and or the tolerances are not spot on. If the frame has been prepped properly here is an easy method.[/SIZE][/FONT] [FONT=Times New Roman][/FONT] [FONT=Times New Roman][SIZE=3]Stick the cups / HS in the freezer for an hour or two. The cold will shrink the metal.[/SIZE][/FONT] [FONT=Times New Roman][/FONT] [FONT=Times New Roman][SIZE=3]Remove from freezer[/SIZE][/FONT] [FONT=Times New Roman][/FONT] [FONT=Times New Roman][SIZE=3]Apply grease to cups / HS and HT[/SIZE][/FONT] [FONT=Times New Roman][/FONT] [FONT=Times New Roman][SIZE=3]Option 1: Tap in with rubber mallet Option 2: Press in with a large C clamp and two pieces of wood.[/SIZE][/FONT] |
#24 (permalink) |
yea I have a king headset on my stumpy now that I would like to remove to keep for any future bikes I may buy, or sell to raise money for other parts, but I have to finish my trance build first, the thought is appreciated, I'm still wondering if I should get the tool, everyone seems to have their own methods...
#25 (permalink) | |
ali'i hua
.8down (11-08-2007)
#27 (permalink) | |
Yep, as long as its flush with the top crown. This is all you need. Basically a long threaded rod, washers and some nuts. if you can find something thicker than washers, but about the same diameter then get those. the guy in the bay ad machines the two big parts, which works great, but a substitution is possible. |
OffRoadie (11-08-2007)
#29 (permalink) | |
Go to the hardware store and see what you can build up simulating what the bay person has. If not then get creative and see what you can piece together. |
#30 (permalink) |
Seriously, I tried the washer and bolt method. It sucks IMO compared to just carefully using a rubber mallet. I actually started bending a small lip on one of my headset cups by using the steel washers to press them in. You won't have that problem with the rubber mallet.
#31 (permalink) | |
ali'i hua
another option that's worked before for me: 4 large washers 2 large nuts (hehehe- he said "nuts") 1 long bolt (not even going there) 2 pieces of wood carved similar to your headset inside diameter (i think this part is key- these help center it. aside from the obvious jokes, with this setup, you can actually create a crude HS press for less than $10. the only issue with this method is getting the cups centered when they get pressed into the frame. |
| IS headset. | .8down | The Workshop | 8 | 10-31-2007 10:11 AM |
| Seat post, Headset, F Derailer, brakes, QR seat clamp | Neccros | The Market Place | 4 | 09-10-2007 02:58 PM |
| Help! Is there a trick to removing the headset shim?! | L8 APEKS | The Workshop | 1 | 04-23-2006 09:06 PM |
| Aheadset DL headset 1 1/4" | mrpoonerson | The Market Place | 2 | 10-26-2005 12:46 AM |
| Intense Uzzi SL frame,Chris King Headset, Race Face Cranks | HeyMoe | The Market Place | 0 | 06-22-2005 07:35 PM |
