Results 1 to 15 of 15
Thread: Tire burn on inside of leg
  1. #1
    STR Veteran CarlS's Avatar
    Apr 2010
    From
    Temecula
    Default Tire burn on inside of leg
    Does anyone else do this???
    I have been mountain biking for about 20 years and for some reason this has just started happening to my legs several times over the last year or two. While descending steep terrain, I somehow lean the bike to one side while I am way back over the saddle and the tire gives my calf or hamstrings a quick "burn" rub. It really hurts like hell when you take a shower later. and it's not the bike, It happens on my Stumjumper FSR and just last night I did it again on my old-school Gary Fisher hard tail. It seems to be a problem with my body english. and I ride mostly cross country / all mountain type riding. not downhill.
    just wondering if anyone else has this problem and what they do about it
  2. #2
    Why do you move so far back when climbing steep terrain? Have you always climbed that way or have you changed recently?
  3. #3
    Sep 2009
    From
    Ladera Ranch
    It sounds like he's saying it happens when he's "navigating" steep terrain. Not climbing. So I'm assuming he's talking about when he's descending.
  4. #4
    Apr 2010
    From
    Temecula
    Quote Originally Posted by melster View Post
    yea. thats it. sorry. descending over drops and turns with the saddle in my chest.
  5. #5
    Tapia Bunny Slayer Magna_Graecia's Avatar
    May 2008
    From
    Long Beach, CA
    ^^If the saddle is in your chest, it's probably way too high which forces you to go too far back over the rear tire. Try dropping your saddle half-way or even slamming it all the way down before doing any steep descents. This will allow you to stay more over the seat/BB instead of sitting on the rear tire.
    Just my $.02.
    “Often I must speak otherwise than I think. This is called 'Diplomacy'.”
    -Frank Herbert
  6. #6
    I cant imagine doing that. I can lean back far enough to rub my butt, but not calf or hamstring.
    Things you could do.
    1) Bend your arms when descending. Its good technique and will decrease the degree to which you are extended behind the bike.
    2) Longer stem. 20mm will do wonders.
    3) Turn your handles bars to reduce sweep.
    4) Larger frame.
    Do you really tip the bike down that much when descending steeps? Doesn the saddle hit you in the arms?
    Good luck!
  7. #7
    Yep my bad sorry.
  8. #8
    Apr 2010
    From
    Temecula
    no, it doesn't hit my arms. all I can say is it seems to happen when I am "gettin it" and riding very aggresive. and actually it doesn't have to be steep, one time I got it when I was flying off a drop and across a deep sand wash and was leaning back to avoid going otb in the sand.
  9. #9
    Quote Originally Posted by Magna_Graecia View Post
    Just my $.02.
    Yup. It's a bit of a PITA to stop and drop the seatpost all the way down BMX style and then raise it every time you have a hill to grind, but the old seat in-the-gut trick is definitly not a good trade versus the freedom and comfort of having that seat all the way down. And I don't get tire burns (different form?) but thats just another reason why you might go ahead and take the time to lower it. Especially when said downhill offers you a jump or leads into some whoops at the bottom. Having the seat up where it should be for climbing is the WORST when you go air it out. It changes the balance of the bike and makes me wonky in the air. No bueno.
    SO! The only other solution, which coincidenatally is where I'm also at right now, is buying an adjustable seat post like the Gravity Dropper...though I have yet to even try one out.
    It's another case of, I just need to spend another $350 and it'll be PERFECT! =(
    ~IamH4V0C
  10. #10
    Quote Originally Posted by CarlS View Post
    Not criticizing. Just offering some info.
    There is a point where you are so far back, even in very steep terrain, that you unload the front and loose steering authority. You know this is happening when you are actually hanging (pulling) on the handle bars as you descend.
    This can be changed by putting your weight on your feet and keeping your hands light. Doing so allows your brain to determine where exactly to position your body, keeps you more forward, your CG on the BB, the front tire better planted, and requires less body english
    You will know you are in the right position when descending when you can stand on the pedals and float your palms a few mm over the grips.
    Theoretically, to his the rear tire with your hamstring while standing on the pedals, I imagine I would have to be descending a 70 degree slope. I could be mistaken.
    Hope that helps.
  11. #11
    Dec 2010
    From
    Laguna Niguel
    drop the seat nice and low, equal to the hight of the stem at least, keep your knees bent and wide, heels down, and make those shapes!!
  12. #12
    That sounds like an entirely different type of rubber burn...
  13. #13
    Senior Member socal_rider's Avatar
    Jul 2009
    From
    Winchester, CA
    Where are you riding at Carl?
  14. #14
    They call me D2 pmortuary's Avatar
    Mar 2008
    From
    Tustin
    Perhaps you problem is not position related but some sort of equipment malfunction? Maybe get something with a little more coverage.
    Attached Images Attached Images
  15. #15
    Apr 2010
    From
    Temecula
    Quote Originally Posted by socal_rider View Post
    The usual. MV-cross hill - sky canyon.
    I guess I am the only one. I can't believe that no one else has done this. maybe it has something to do with my broken feet.
  16.    Sponsored Links
  1. Noise Coming from Inside Tire
    By Cilantro13 in forum The Workshop
    Last Post: 02-24-2011, 07:44 AM
  2. Tire Burn Hurts
    By bwolmarans in forum Rider Down
    Last Post: 11-18-2009, 08:55 PM
  3. Feel the Burn!
    By bobzrag in forum General Discussion
    Last Post: 05-11-2008, 12:14 PM
  4. Sun Burn ...
    By Blue Rat in forum The Pub
    Last Post: 04-07-2008, 07:38 PM
  5. Sun Burn ...
    By Blue Rat in forum General Discussion
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
