Results 1 to 9 of 9
Thread: Nalgene bladders....fix kits?
  1. #1
    Circus Bear Chewyeti's Avatar
    Jul 2007
    From
    Yorba Linda
    Default Nalgene bladders....fix kits?
    I have a nalgene bladder which ate an oring on the hose... and now the valve on the bladder (quick disconnect) leaks also....
    where can i source replacement bladders or parts? My bite valve also leaks.....
    Resident Lawn Dart
  2. #2
    Having upgraditis is OK dubjay's Avatar
    Apr 2005
    From
    Quote Originally Posted by Chewyeti View Post
    http://www.camelbak.com
  3. #3
    Crash Test Dummy gone2vegas's Avatar
    May 2009
    From
    Irvine, CA
    It's not that I'm lazy, it's that I just don't care.
  4. #4
    STR Veteran jeff^d's Avatar
    Sep 2008
    From
    Claremont
    REI, if you need to shop in person.
  5. #5
    member CalEpic's Avatar
    Feb 2005
    From
    Laguna Niguel
    If it came with a Dakine pack, Dakine CS will send you a new one at no charge.
    After going through several Nalgene replacement bladders with various leaks I offer the following suggestion - save yourself the time and wet back. Just put a Camelbak bladder in and be done with it. Not trying to be a smart ass but the Nalgene bladders are the biggest POS's ever made. Great design, poor execution.
    Edit - if you're just replacing the bite valve, the Camelbak valve will not work. It's a smaller ID fitting.
  6. #6
    Jul 2007
    From
    Yorba Linda
    craigster,
    i think i may jump on the 'go back to camelbak' bladdders band wagon....
    Thanks guys.
    Resident Lawn Dart
  7. #7
    POWERED BY MUSUBIS F.A.D.'s Avatar
    Oct 2007
    From
    Alta Loma
    Another good bladder from my experience has been with the Deuter. It's been leek free so far and I find it easier to clean (wider top opening).
  8. #8
    i used teflon tape over the o-ring. def helps the problem. but overtime, as you remove the hose the tape will wear out. but just tape it over again and your good to go!
    SoCal RallyX Coverage and MTB Ride Reports
    WheelsDirty | Facebook | Twitter | Instagram
  9. #9
    i ride bikes
    Nov 2007
    From
    Fullerton
    I went through a few nalgene bite valves and they leaked or eventually got holes in them. I just went and got a camelbak brand bladder/valve and so far so good.
    BTW, the path had nalgene bite valves, not sure about bladders. Save your money and go camelbak.
    flickr
    1993 Specializd Stumpjumper
    Specialized Rockhopper
    Surly Cross Check
  10.    Sponsored Links
  1. Cleaning Sho-Air (or White) Kits
    By MTBMaven in forum Racing and Training
    Last Post: 10-12-2009, 04:49 PM
  2. FS: 2 Camelbak Mules + 3l Bladders also S & M mtn helmets
    By culturesponge in forum The Market Place
    Last Post: 08-16-2009, 09:30 AM
  3. FS: Goodridge Brakeline Kits
    By jeffj in forum The Market Place
    Last Post: 06-11-2008, 08:03 PM
  4. camelbak bladders, how long has yours lasted?
    By faded1004 in forum General Discussion
    Last Post: 05-12-2008, 08:59 AM
  5. Any hydration bladders that DONT leave a funky taste?
    By Flat Broke in forum General Discussion
    Last Post: 03-18-2008, 06:18 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
