Results 1 to 9 of 9
Thread: Avid Elixir Adjustment
  1. #1
    Jul 2009
    From
    LA/SF Valley
    Thanks
    15
    Thanks earned: 42
    Default Avid Elixir Adjustment
    Newbie needs help with Elixir R. It came with the used bike, but they were new. They worked great during my last ride but I just noticed that the Front lever depresses all the way to the grip and I can't seem to adjust the play. (I have no instructions) It grabs, but not that strong.
    No signs of leak but the "Reach In" knob thing is now really tight and I had to turn it using the hex head screw on the inside the lever.
    Also, I transported the bike with the wheel off and nothing between the pads. I heard it's not good for hydro brakes if there's no rotor or spacer in between the pads and lever is depressed...
    All help is appreciated. Thanks!
    Attached Images Attached Images
  2. #2
    LukeTrailrider's Avatar
    Sep 2009
    From
    Upland, CA
    Thanks
    207
    Thanks earned: 480
    I had the same problem with my rear Elixer CR, which lead to a bigger problem when I tried using the pad contact adjustment to address the problem. Long story short, it came apart and I had to send it in for a warranty replacement. My guess is that fluid loss caused the intial problem. My advice would be to have them bled and refilled. If the problem happens again after that, contact avid.
  3. #3
    STR Veteran 92se-r's Avatar
    Oct 2007
    From
    San Diego
    Thanks
    3,314
    Thanks earned: 2,925
    You need to reset the piston probably because you might have squeezed the levers with the wheel off.
    Take the pads off, push the pistons back in with a 10mm box wrench. Then put the pads back in, loosen the caliper bolts, and squeeze away with the wheel back on. If the lever still goes to the handlebar, take the pads off, squeeze the levers halfway and pump a few times. Do not squeeze all the way to the handlebar. Watch your piston come out a bit, replace the pads, and see how it feels with the wheel back on. If it feels good, hold the lever down, tighten the caliper bolts. Done.
  4. post thanked by:
    Junta (11-24-2009)
  5. #4
    Circus Bear Chewyeti's Avatar
    Jul 2007
    From
    Yorba Linda
    Thanks
    15,222
    Thanks earned: 16,326
    bleed em....
    I had a random fluke with an elixir R, some fluid SOMEHOW got behind the master cylinder piston.... i think it happenned after i crashed....
    Bled it, and it all got better.
    Resident Lawn Dart
  6. #5
    cookie monsta SnookDawg's Avatar
    Feb 2008
    From
    San Diego
    Thanks
    141
    Thanks earned: 164
    Did you depress the lever without anything in the caliper? It's not clear from your post.
  7. #6
    Jul 2009
    From
    LA/SF Valley
    Thanks
    15
    Thanks earned: 42
    Thanks All. I might have to do that. Resetting didnt do the job. Theres still too much play in the lever. I will have to invest in a bleed kit and try it for the first time. I guess Mexican hills were too bumpy for the brakes and maybe it leaked just enough...
    Yes, I probably depressed it while there was nothing in the caliper. Still not sure what that does...
  8. #7
    Tink's first sponsor NipomoGuy's Avatar
    Nov 2009
    From
    Nipomo, CA
    Thanks
    628
    Thanks earned: 907
    it extends the pistons out, and with nothing between them, they will stay out. re set them, bleed them and go from there. The bleed kit is a good investment, mine paid for itself the second time i used it (got it for $47.00, the shop charges 25$ for a brake bleed).
  9. #8
    Booze Bikes n Boomsticks SAR_boats's Avatar
    Oct 2006
    From
    Other
    Thanks
    5,960
    Thanks earned: 5,165
    I would be willing to bet that the lever was depressed a few times and your master cylinder reservoir was close to empty when you had the wheel off. Once the master cylinder runs out of brake fluid it will cause a bubble to get into the brake line since there is no fluid to actuate the system. Sometimes just resetting the pistons will get the bubble out and make everything ok, sometimes not. Do a good bleed on the system. If you are going to try bleeding it yourself you may have to do it a couple times before you get it right.
    The contents of the above post may not be safe for children, expectant mothers, or the elderly. The above post should probably not be taken seriously but should be taken with a quart of whisky. Misuse of the above post may cause rash, infection, joint pain, bleeding gums, car trouble, bad weather, black mold and/or anal seepage.
  10. #9
    Always be a moving target Fewinhibitions's Avatar
    Feb 2009
    From
    Da 808
    Thanks
    5,031
    Thanks earned: 4,808
    I would concur with the other posts. I would also get a clip for when the wheel is off.
    Just an FYI if you do a lot of DH, you will need to bleed every so often - after a while the fluid gets overheated heated and loses its effectiveness.
    The lever losing it's power is a usual signal for this as well.
    We must train our minds to desire what the situation demands.
    Religion is fundamentally opposed to everything I hold in veneration--courage, clear thinking, honesty, fairness...and, above all, love of the truth.
    Life, freedom, and the pursuit of those who attempt to destroy it.
  11.    Sponsored Links
  1. WTB: Avid Elixir CR Carbon Lever blade
    By LukeTrailrider in forum The Market Place
    Last Post: 10-30-2009, 11:32 PM
  2. Replies: 10
    Last Post: 10-30-2009, 06:49 PM
  3. 185 / 180 Avid Elixir ?????
    By Cannonball in forum The Workshop
    Last Post: 09-04-2009, 09:08 AM
  4. FS: Avid Elixir R 185 / 160 Brand New in Box
    By mtnbikej in forum The Market Place
    Last Post: 08-16-2009, 11:41 AM
  5. FS: Avid Elixir CR White 203 / 185 New In Box
    Last Post: 08-16-2009, 11:06 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
