Results 1 to 7 of 7
Thread: Help with a stuck brake piston
  1. #1
    Apr 2007
    From
    Aliso Viejo
    Thanks
    345
    Thanks earned: 413
    Default Help with a stuck brake piston
    So one of the pistons on my Saints is stuck, completely retracked into the caliper. I tried bleeding the brakes and that didn't help, any suggestions how to get it unstuck and working again? BTW the other piston still works. Thanks.
  2. #2
    Jul 2006
    From
    RSM
    Thanks
    4,041
    Thanks earned: 2,746
    Did you try holding the non stuck piston in the caliper while squeezing the brake lever? Try lubing the stuck piston with triflow before you do this.
  3. post thanked by:
    Pato (03-24-2009)
  4. #3
    Circus Bear Chewyeti's Avatar
    Jul 2007
    From
    Yorba Linda
    Thanks
    15,216
    Thanks earned: 16,324
    well, sounds like you will be doing a rebuild soon....
    so what you can do is split the caliper open. From there, you can use compressed air to blow the piston out.
    Or while it is still together, hold the free piston (as rob said) with a clamp of some sort, and force the non moving piston to free itself under the hydraulic pressure.
    Once you get it apart and unstuck... rebuild it and bleed it. Polish the piston and the bore with UBER fine sandpaper... 2000gritt +
    Resident Lawn Dart
  5. post thanked by:
    Pato (03-24-2009)
  6. #4
    anachronistic and impulsi Fearless Fly's Avatar
    Jan 2007
    From
    Brea, CA
    Thanks
    426
    Thanks earned: 4,573
    Lube it up.
    Attached Images Attached Images
  7. post thanked by:
    Chewyeti (03-24-2009), Pato (03-24-2009), Rob (03-24-2009)
  8. #5
    STR Veteran davidB's Avatar
    Jul 2007
    From
    Tustin
    Thanks
    4,072
    Thanks earned: 9,692
    Quote Originally Posted by Chewyeti View Post
    is it as hard as you've made it seem or not? Seems about time to tear apart my Juicy 7's. I figure I might try polishing them while they're apart
  9. #6
    Jul 2007
    From
    Yorba Linda
    Thanks
    15,216
    Its really easy....
    Bring em by with some beer and a rebuild kit
    Resident Lawn Dart
  10. #7
    Apr 2007
    From
    Aliso Viejo
    Thanks
    345
    Thanks earned: 413
    Thanks for the advice. I already tried holding in the other piston and lubing up the one that is stuck but no dice. I guess it just needs to get re-built.
  11.    Sponsored Links
  1. Replies: 4
    Last Post: 02-03-2009, 01:02 PM
  2. Avid 7 Brake Noise
    By shudder in forum The Workshop
    Last Post: 01-08-2009, 03:53 AM
  3. unequal piston movement in hyd. brake
    By UR2KLOS in forum The Workshop
    Last Post: 10-31-2008, 07:35 AM
  4. Hayes Disc Brake 5" Rotor
    By BobBurnes in forum The Workshop
    Last Post: 02-25-2008, 03:55 PM
  5. Piston Stuck?
    By b5driver in forum The Workshop
    Last Post: 01-14-2008, 11:27 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
