Results 1 to 6 of 6
Thread: Rear wheel doesn't spin freely, help?
  1. #1
    Sep 2008
    From
    Anaheim/Fullerton
    Thanks
    Thanks earned: 34
    Default Rear wheel doesn't spin freely, help?
    Hi,
    I'm a newbie when it comes to bike repair/maintenance but i noticed yesterday when i was at the fully loop that my rear wheel does not spin very well. When i flip my bike upside down and spin my wheels, my front wheel will make several rotations before it gradually comes to a stop, however the rear wheel will only make maybe 4-5 rotations and then stops.
    what should be some of the first things i check to fix this problem?
    btw, i don't believe it's brakes related.
    thanks.
    kno=whats up with ppl and guns? .. is it cool now a days? Fingers=No its not cool, its called not becomming a victim.
  2. #2
    Circus Bear Chewyeti's Avatar
    Jul 2007
    From
    Yorba Linda
    Thanks
    15,221
    Thanks earned: 16,326
    what hubs?
    could be a dragging free body.....
    you sure its not brakes?
    Resident Lawn Dart
  3. post thanked by:
    BFloFoxRider. (03-17-2009)
  4. #3
    sandbagger autoduel's Avatar
    Aug 2007
    From
    Mission Viejo
    Thanks
    2,585
    Thanks earned: 2,988
    No disrespect, but you are spinning it in the normal direction and not backwards where it spins the cranks right?
    Steve
    Just along for the ride
  5. #4
    Sep 2008
    From
    Anaheim/Fullerton
    Thanks
    Thanks earned: 34
    none taken,
    yes i'm spinning it in the normal direction. I'll have to check my brakes again but i am fairly certain that's not what it is.
    as far as what hub, i honestly don't know. whatever the 2008 specialized FsrXc expert comes with.
  6. #5
    Aug 2007
    From
    Mission Viejo
    Thanks
    2,585
    If the crank turns when spinning in the normal direction, it's the freehub binding.
    Also take the wheel out and spin it in your hands, holding the axle with both hands. You can feel if the bearings are tight when the axle wants to turn. Also lube any rubber seals around the axle.
    Steve
  7. #6
    STR Veteran Edog's Avatar
    Feb 2007
    Thanks
    452
    Thanks earned: 986
    If you have regular bearings rather than sealed chances are your hub could be to tight. If you don't have the right tools to loosen it up a little I'd check with your LBS or maybe somebody could meet at the loop to take a look
  8.    Sponsored Links
  1. Need rear rim brake wheel cheap!!!, free??
    By Lor in forum The Market Place
    Last Post: 01-30-2009, 10:59 PM
  2. WTS: Über-lite 29er Singlespeed rear wheel $350
    By Padre in forum The Market Place
    Last Post: 12-13-2008, 04:00 PM
  3. 8" rotors with rear wheel QR
    By 92se-r in forum The Workshop
    Last Post: 12-12-2008, 08:31 AM
  4. Rear wheel clicks
    By NA1NSXR in forum The Workshop
    Last Post: 09-22-2008, 08:51 PM
  5. 150mm rear DEE MAX Wheel
    By RFXIbibisTom in forum The Market Place
    Last Post: 05-02-2008, 06:29 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
