Page 1 of 2 1 2 LastLast
Results 1 to 20 of 33
Thread: Foolproof way to align handlebars with front tire?
  1. #1
    Senior Member newpos's Avatar
    Jun 2008
    From
    by da beach
    Thanks
    562
    Thanks earned: 285
    Default Foolproof way to align handlebars with front tire?
    How do you do it? anyone have a guaranteed way to quickly and easily align the bars with the front tire?
  2. post thanked by:
    El Salt (10-10-2008), Kish Me (10-11-2008)
  3. #2
    El Salt
    Guest
    Lasers.
  4. post thanked by:
    boludo (10-10-2008), BrewMaster (10-11-2008), Chewyeti (10-11-2008), gooseaholic (10-10-2008), ryandood (10-11-2008), TrojanInsomniac (10-12-2008)
  5. #3
    STR Veteran davidB's Avatar
    Jul 2007
    From
    Tustin
    Thanks
    4,072
    Thanks earned: 9,692
    I just look at it.
    /smartass answer
    actually I found one of these laying around the house last time
    ^t-square ruler
    hung a string w/ weight off the end and over my front tire and aligned it from there.
    Now I just look at it, it wasn't worth the hassle.
  6. post thanked by:
  7. #4
    Senior Member solo_rider's Avatar
    Dec 2007
    Thanks
    68
    Thanks earned: 309
    Default Instructions For Precision Front Tire Alignment
    Tools Required:
    3.5mm hex wrench
    6 pack of Guiness
    Park tool laser cut bottle opener
    Instructions:
    Step 1. Loosen 2 hex bolts at stem. DO NOT over-loosen the bolts. Stem should still have some grip on the steerer tube.
    Step 2. Grab beer from 6 pack
    Step 3. Open beer using Park Tool bottle opener
    Step 4. Drink beer
    Step 5. Repeat steps 2-5 five times for best results
    Step 6. Sit on bike and carefully align centerline of the stem with the front tire. You may need to close one eye and tilt your head a few degrees to find the exact centerline.
    Step 7. Torque hex bolts to spec.
    Step 8. Take bike for a spin.
    If for any reason this method doesn't work, try it again with a different brand of beer. Fat Tire and Widmer are also choice mechanical fluids.
  8. post thanked by:
    b-40 (10-11-2008), Cableguy (10-12-2008), Chewyeti (10-11-2008), dirtyjeff (10-11-2008), DirtymikeTDB (10-11-2008), DownHillPhil (10-11-2008), dubl_xl (10-11-2008), El Salt (10-10-2008), F.A.D. (10-13-2008), gray (10-11-2008), jhardeman (10-12-2008), KonaDupee (10-12-2008), kyoseki (10-10-2008), lukewiens (10-11-2008), mtnbkrdavid (10-12-2008), onlyontwo (10-12-2008), Pato (10-11-2008), simonmtb (10-16-2008), TrojanInsomniac (10-12-2008), wannagobig (01-03-2009)
  9. #5
    El Salt
    Guest
    Quote Originally Posted by solo_rider View Post
    Tools Required:
    3.5mm hex wrench
    6 pack of Guiness
    Instructions:
    Step 4. Drink beer
    Well, if you don't have access to high power lasers, then this will work. However, I suggest a darker beer than suggested above.
    Last edited by El Salt; 10-10-2008 at 10:05 PM. Reason: Oops, I missed that (Guiness), yes, that will do...
  10. post thanked by:
  11. #6
    STR Veteran Tedroy's Avatar
    Jun 2007
    From
    Pasadena Ca
    Thanks
    2,345
    Thanks earned: 3,703
    Default Eyeball it!
    Tools only complicate this. Intuition should tell you if something is a mm off. Ride w/ the stem just slightly loose so you can do the ol' kick it 'till it's straight routine. Torque it down when it's right.
  12. post thanked by:
    BrewMaster (10-11-2008), rubrduk (10-11-2008)
  13. #7
    STR Veteran gooseaholic's Avatar
    Oct 2007
    From
    Orange,ca Via Seattle, WA
    Thanks
    16,598
    Thanks earned: 11,640
    Dont forget, If you close the right eye, stick the tongue out to the left. Vice versa. It is a natural point of balance. Make sure the head is straight and the nose is aligned with the center of the tire. If you have broken your nose, adjust to the angle of the break + or - 2 degrees.
    When you have more than you think, you need more space. Society you are a crazy breed,I hope you wont be lonely without me.
    We are opinions so filled with hatred.
  14. post thanked by:
    BrewMaster (10-11-2008), Chewyeti (10-11-2008), Danimal (10-12-2008), dirtyjeff (10-11-2008), El Salt (10-10-2008), KonaDupee (10-12-2008), onlyontwo (10-12-2008), Pato (10-11-2008)
  15. #8
    El Salt
    Guest
    Quote Originally Posted by bighit8 View Post
    Nice. Very nice!
  16. post thanked by:
  17. #9
    Oct 2007
    From
    Thanks
    16,598
    Quote Originally Posted by newpos View Post
    Just giving a razz newpos. Sorry.
  18. #10
    El Salt
    Guest
    Yea, here too. I ALWAYS end up doing this (re-center) like two or three times, anytime I mess with my stem, headset, or spacers. I'm a bit anal when it comes to things like getting my bars / stem at 90 degrees to my wheel. Its just a matter of sighting down the top tube of your frame and your front wheel. It takes a little time. Just tighten your stem slightly, and then "nudge" your bars right or left until you are happy. Then tighten, using a torque wrench (idealy).
  19. #11
    Jun 2008
    From
    by da beach
    Thanks
    562
    Thanks earned: 285
    haha no harm no foul...
    i considered doing this until i figured i'd look like an ass...
    i'll probably end up bungie-cording the front wheel to the seat tube to straighten things out from there, just wondering if there was an easier way...
  20. post thanked by:
    gooseaholic (10-12-2008)
  21. #12
    DH'r in a rigid 9'rs body Kish Me's Avatar
    Sep 2007
    From
    Dana Point
    Thanks
    1,165
    Thanks earned: 800
    I could problably lace a wheel faster than I can align my handlebars
    But, one thing is for sure... When it's right, it definately feels right
  22. post thanked by:
    El Salt (10-11-2008)
  23. #13
    Banned
    Oct 2007
    From
    Thanks
    11,345
    Thanks earned: 5,321
    Stand in front with the front wheel between your knees, use a crack in the sidewalk or slab in you garage as a plumb and try to keep the center strip of tread in between the face plate bolts. If none of this works for you call the path (714) 669-0784.
  24. #14
    professional lurker rubrduk's Avatar
    Sep 2008
    From
    la canada
    Thanks
    28
    Thanks earned: 26
    +1...quoted for posterity
    Quote Originally Posted by Tedroy View Post
  25. #15
    STR Veteran singlespeedrider's Avatar
    Jul 2008
    From
    Thanks
    1,701
    Thanks earned: 1,081
    Tools Required:
    3.5mm hex wrench
    6 pack of Guiness
    Instructions:
    Step 4. Drink beer
    This is my method but with Coors Original in hand.
    If I am a little off I just go with it, you get used to it and your mind corrects for the slight difference in a few miles
  26. #16
    DirtymikeTDB
    Guest
    Everyone forgot an the almighty important step of scratching your junk before you give the final twist on the bolts!!!
  27. post thanked by:
    gooseaholic (10-11-2008), slo65 (10-13-2008)
  28. #17
    The same, but different dirtyjeff's Avatar
    Aug 2008
    From
    RSM
    Thanks
    4,175
    Thanks earned: 1,704
    Quote Originally Posted by singlespeedrider View Post
    Not to get too technical, but with Coors original there is a 4.8 degree (+/-) tolerance.
    What happened to the good ol' days of putting your front tire between your legs and smacking your grip til it was right where you wanted it to be? Wait that was on my stingray. Nevermind, buy a laser and some beer!
  29. post thanked by:
    singlespeedrider (10-12-2008)
  30. #18
    Bloated Mountain B'hiker jeffj's Avatar
    Jul 2007
    From
    Castaic, CA
    Thanks
    8,737
    Thanks earned: 5,402
    Quote Originally Posted by DirtymikeTDB View Post
    Note to self: Never borrow dirtymike's 5mm allen wrench.....
    Come to think of it, you might not want to borrow mine either....
  31. post thanked by:
    dirtyjeff (10-12-2008), DirtymikeTDB (10-11-2008), Pato (10-12-2008)
  32. #19
    A little Shaggy Bryguy17's Avatar
    Dec 2007
    From
    Fullerton, CA
    Thanks
    7,333
    Thanks earned: 6,979
    take the wheel off, place the dropouts at the bottom of a wall. pick the back of the bike up until the handlebars touch the wall. tighten bolts as necessary.
    oh, and drink a 6-pack while you do it for good measure
  33. post thanked by:
    jeffj (10-13-2008), newpos (10-12-2008), Pato (10-12-2008)
  34. #20
    Intense Whore mfoga's Avatar
    Apr 2008
    From
    Thanks
    4,598
    Thanks earned: 8,587
    Go with a dual crown fork and get direct mount stem
  35.    Sponsored Links
  36. post thanked by:
    F.A.D. (10-13-2008)
  1. 29er Tire Combos/Recommendations
    By BrewMaster in forum The Workshop
    Last Post: 06-09-2014, 04:28 PM
  2. Tire Review Thread
    By guero in forum The Workshop
    Last Post: 03-19-2014, 09:00 PM
  3. mountain bike slang directory
    By 26'er Zen Master in forum General Discussion
    Last Post: 09-26-2010, 03:25 PM
  4. Front Tire Suggestion
    By GhostMan in forum General Discussion
    Last Post: 08-23-2008, 08:37 AM
  5. Tire problem
    By Dino Brown in forum The Workshop
    Last Post: 12-26-2007, 08:34 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
