Results 1 to 4 of 4
Thread: Stem Question: 25.4 vs. 31.8?
  1. #1
    Isaiah 52:7 quaestionis's Avatar
    Oct 2007
    From
    RB/4S Ranch
    Thanks
    266
    Thanks earned: 327
    Default Stem Question: 25.4 vs. 31.8?
    What is the difference (besides size) between a 25.4 and 31.8 stem/handlebar?
    Is there an advantage of one over another? Standard size vs. harder to find parts for? I'm confused.
  2. post thanked by:
    DISCO (09-02-2008)
  3. #2
    Banned
    Oct 2007
    From
    Thanks
    11,345
    Thanks earned: 5,321
    Oversize is marginally stiffer due to the larger tube but also slightly heavier. Today nearly all reputable carbon bars are 31.8, whereas most jumping/DH riser bars have a one inch clamp. I ride a Black market 3" rise and feel some flex but it's not enough to fatigue the material. So if you are tall and want a bar that is higher that a 1.5" rise go 25.4
  4. post thanked by:
    quaestionis (09-02-2008)
  5. #3
    A little Shaggy Bryguy17's Avatar
    Dec 2007
    From
    Fullerton, CA
    Thanks
    7,333
    Thanks earned: 6,974
    both will be easy to find parts for, it's just a difference in attributes.
    31.8 OS will be a stiffer bar, but will also be a little stronger. In some cases, (not all mind you) you might end up with a slightly lighter stem as well, but not usually. OS seems to be the trend for most new bikes. I personally like the extra stiffness, as it adds control and tactile feedback.
    25.4 will be a flexier bar, but not necessarily weaker. the bar will take up more of the vibrations from the trail, so your hands dont feel them. pretty much every bar has a 25.4 size, so finding one wont be a problem. These will also be much cheaper, as they are technically out of vogue. you can find a good carbon bar/stem combo for a comparable price to a nice OS stem.
    Another thing to consider: should you want to run a titanium bar, you will want to go 25.4. As far as I know they only come in that size due to the difficulty in making a ti OS bar. it's a bling option though, so not really a big deal
  6. post thanked by:
  7. #4
    DirtymikeTDB
    Guest
    Almost every single bike coming out now that isnt entry line has 31.8 bars. we have 4 out of 50 bars in teh shop that are 25.4 Seems 31.8 is the new standard. Anything you gain weight wize on teh bar, your going to make up on the stem. Stronger, stiffer. the 31.8 is the way to go. Even the road bikes are that way too
  8.    Sponsored Links
  9. post thanked by:
  1. WTB: cheap 1" quill stem 25.4 clamp
    By dutch in forum The Market Place
    Last Post: 08-03-2008, 01:51 AM
  2. Thomson stem (black) 5x90mm 25.4 clamp
    By Padre in forum The Market Place
    Last Post: 05-26-2008, 08:00 AM
  3. Question about stem rise…..
    By jebfour in forum The Workshop
    Last Post: 03-20-2008, 01:49 PM
  4. 1 1/8 60-80mm 25.4 stem
    By Jslow in forum The Market Place
    Last Post: 01-31-2008, 03:23 PM
  5. Thomson 90mm or 100mm stem, 25.4
    By guero in forum The Market Place
    Last Post: 09-12-2007, 10:15 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
