Results 1 to 16 of 16
Thread: Correct way to deglaze brake rotors/pads?
  1. #1
    Wanna ride? Solo's Avatar
    Dec 2007
    From
    Carlsbad
    Thanks
    890
    Thanks earned: 399
    Default Correct way to deglaze brake rotors/pads?
    I've heard of several ways to deglaze brake rotors and pads from sanding them in a figure eight pattern to baking them in the oven.
    I'm currently running Avid Juicy 5's with stock pads for about 200 miles or so and noticed a dramatic decrease in braking power from the rear as well as dark black streaks on the rotor.
    Does anyone know the correct way to fix this?
  2. #2
    Ride More Talk Less foofighter's Avatar
    Jul 2007
    From
    Aliso Pendejo
    Thanks
    7,254
    Thanks earned: 7,136
    i just take fine grit sandpaper sping the wheel on the bike and pinch the sandpaper over the rotor to clean the glaze off...worked for me for a few rides.
    On Sabatical - Out Riding
    10 Pinarello Dogma
    My Roadie Blog
    Family Bog
  3. post thanked by:
    Red Hot Sloth (02-20-2008), Solo (02-20-2008), un-kola (02-20-2008)
  4. #3
    northshore's Avatar
    Oct 2007
    From
    Laguna Hills, CA
    Thanks
    5,109
    Thanks earned: 3,415
    Quote Originally Posted by foofighter View Post
    +1..fine grit sandpaper and then finish it off with a mild towel soaked with a bit of brake cleaner and you should be golden.
    Hawaiian Island Creations
    Make a difference: www.imba.com
  5. post thanked by:
  6. #4
    Banned
    Oct 2007
    Thanks
    4,300
    Thanks earned: 5,127
    The pads themselves can develop a glaze on them as well. I give them a quick sanding with a fine grit as well..not as vigorous as its done on the rotor though, just enough to break away the glaze. And don't use any fluids on the pads, just blow 'em off
  7. post thanked by:
    Dirty Boo (02-27-2008), foofighter (02-20-2008), LlammaPudge (03-27-2008), northshore (02-20-2008), Sizzle Chest (03-27-2008), Solo (02-20-2008), un-kola (02-20-2008)
  8. #5
    Aug 2007
    From
    south OC
    Thanks
    294
    Thanks earned: 479
    I just take the pads out and do a light file on them.
    The rotors, use fine sandpaper. Then follow up with rubbing alcohol on a clean towel. If Im out of alcohol I have even used windex.
  9. post thanked by:
    Solo (02-20-2008)
  10. #6
    Just another Homer!
    Oct 2007
    From
    San Dimas,Ca.
    Thanks
    4,674
    Thanks earned: 1,823
    What Foo and RHS said,but make sure you don't touch them with your fingers and get oil on them.- Lloyd
    Damn,gunna need a lot of stitches for this one.
  11. post thanked by:
    foofighter (02-20-2008), Red Hot Sloth (02-20-2008), Solo (02-20-2008)
  12. #7
    Dec 2007
    From
    Carlsbad
    Thanks
    890
    Thanks earned: 399
    Thanks guys, I'll try that when I get home. Looking out the window, I'll have a few days to mess around with this (among other things).
  13. #8
    kanga's Avatar
    Oct 2007
    From
    Eagle Rock
    Thanks
    4,800
    Thanks earned: 9,444
    The "baking in the oven" option isn't for de-glazing, in my understanding. I did it once when a bottle of oil-based lubricant (3 in 1) leaked in my tool case and my new replacement pads got oil on them. After doing some research, I baked them to burn off the oil, gave them a light sanding with fine-grit sandpaper, blew off the carbon with compressed air, then put them on the bike and had no real problems. I can't remember the settings but I think it was about 400 deg for 30 minutes or so, until toasty brown... They were magura pads and it also baked the paint off the backing plates, but that never caused a problem.
    To expand your comfort zone, you have to leave it!
    http://www.BioniconUSA.com
    http://www.OTBMBC.com
    http://www.CORBAmtb.com
  14. post thanked by:
    Solo (02-20-2008)
  15. #9
    STR Veteran jschwart73's Avatar
    Nov 2007
    Thanks
    288
    Thanks earned: 643
    For motorcycles, we used to use ScotchBrite pads to deglaze rotors. Worked like a charm, just spin the wheel and squeeze the rotor.
  16. post thanked by:
    Solo (02-20-2008)
  17. #10
    Dec 2007
    From
    Carlsbad
    Thanks
    890
    Thanks earned: 399
    Quote Originally Posted by jschwart73 View Post
    Thanks, that's what I was thinking instead of sandpaper. I still have some of the good ones from Uncle Sam that I may dip in alcohol and give them a spin.
  18. #11
    Banned
    Oct 2007
    Thanks
    4,300
    I have used sandpaper, steel wool, and emery cloth and krokus cloth. I prefer the emery cloth, but will use any of these materials
  19. post thanked by:
    Dirty Boo (02-27-2008), LlammaPudge (03-27-2008), Sizzle Chest (03-27-2008), Solo (02-21-2008)
  20. #12
    Epic Builder GP_pilot's Avatar
    Aug 2007
    From
    Ramona, CA
    Thanks
    495
    Thanks earned: 3,560
    Brake pads - Belt sander
    Rotors - Never had glazing, but they'll warp or get high points. Once they do, you're buying new rotors anyway
  21. post thanked by:
    Solo (02-21-2008)
  22. #13
    STR Veteran 92se-r's Avatar
    Oct 2007
    From
    San Diego
    Thanks
    3,313
    Thanks earned: 2,922
    200 grit sandpaper and brake cleaner. DONE.
  23. post thanked by:
    Solo (02-21-2008)
  24. #14
    Oct 2007
    From
    Villa Park, CA
    Thanks
    26
    Thanks earned: 59
    For the pads I use a diamond encrusted flat metal plate intended for sharpening woodworking chisels. For the rotors I use a palm sander with 320 grit sandpaper.
  25. #15
    Feb 2008
    From
    Chino Hills, CA
    Thanks
    7
    Thanks earned: 30
    for the pads i sand the top layer that looks like oily. and for the rotors i usually just wipe it with rubbing alcohol. works for me!
  26. #16
    Code Blue
    Guest
    Default +1
    Quote Originally Posted by crazyjeys View Post
    Also my method
  27.    Sponsored Links
  1. brake pads rubbing
    By JOx2 in forum The Workshop
    Last Post: 01-24-2008, 07:33 PM
  2. Avid Hyd. Disc Brake Upgrade question
    By amor587 in forum The Workshop
    Last Post: 11-29-2007, 02:00 PM
  3. Hayes Brake Rotors & Pads
    By project_d in forum The Workshop
    Last Post: 10-17-2007, 08:40 PM
  4. Check your brake cables
    By UR2KLOS in forum General Discussion
    Last Post: 09-06-2007, 11:28 PM
  5. Brake lever pin missing
    By Paul000 in forum The Workshop
    Last Post: 08-07-2007, 11:09 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
