Results 1 to 12 of 12
Thread: Fox 650B Warning
  1. #1
    Look Ma - No hands! ghixon's Avatar
    May 2007
    From
    Running Springs, Ca
    Thanks
    2,134
    Thanks earned: 2,512
    Default Fox 650B Warning
    After reading about the new 650B tire size, I started looking around and found this warning over on 29".com and on BRAIN.
    Fox Racing Shox Warning to Customers
    WATSONVILLE, CA (BRAIN)—This is a warning against unapproved use of Fox Forks from Fox Racing Shox.
    FOX 32, 36, and 40 suspension forks (with the exception of model F29) are engineered and tested for use with 26-inch mountain bike tires. These models meet CEN and AST M testing standards based on use with 26-inch tires.
    Use of Fox forks with any tire larger than 26 inches, such as a 650b tire, will subject the Fox fork to loads and forces it has not been designed or certified to meet.
    Fox 32, 36, and 40 suspension forks are not recommended or approved by Fox Factory, Inc. for use with tires larger than 26 inches, either as original equipment or aftermarket, according to Fox's Elayna Caldwell.
    Unauthorized and unapproved use of these forks with tires larger than 26 inches may result accidents, causing serious bodily injury or death.
    'Obsessed' is a word that the lazy use to describe the dedicated. - Anon
  2. post thanked by:
    BrewMaster (01-06-2008), denmother (01-07-2008), Do Work (01-06-2008), GeorgiaOfTheJungle (01-06-2008), gooseaholic (01-06-2008), jdavid (07-03-2010), northshore (01-07-2008), number7s (01-06-2008), station (01-07-2008)
  3. #2
    number7s number7s's Avatar
    Jan 2007
    From
    san bernardino
    Thanks
    152
    Thanks earned: 157
    thanks for the heads up
  4. #3
    Zack Attack tkblazer's Avatar
    Feb 2006
    Thanks
    4,182
    Thanks earned: 9,205
    way to cover your butts Fox
    SurlyGal: I kept waiting for it to get hard and it never did
  5. post thanked by:
    DeeZee (01-07-2008)
  6. #4
    northshore's Avatar
    Oct 2007
    From
    Laguna Hills, CA
    Thanks
    5,109
    Thanks earned: 3,415
    That's good to know. I've "heard" of stories of folks converting their 26er fork to a 29er.
    Hawaiian Island Creations
    Make a difference: www.imba.com
  7. #5
    STR Veteran Evel Knievel's Avatar
    Jan 2005
    From
    SoCal
    Thanks
    156
    Thanks earned: 63
    If there is enough to worry about , then that must signal the arrival of the 650B.
    rally the ponies.
    !!! 650B is here !!! 650B is here !!!
    Welcome, Evel Knievel.
    You have 666 Unread Posts - STR
  8. post thanked by:
    PacMan (01-07-2008)
  9. #6
    Jan 2007
    Thanks
    8,378
    Thanks earned: 12,420
    Quote Originally Posted by northshore View Post
    There is a guy doing them on MTBR. He's done a Fox 40 and I think a 36?
    I'd be really nervous to grind away that much material on an expensive fork.
  10. #7
    Banned PacMan's Avatar
    Nov 2004
    From
    that one place
    Thanks
    4,613
    Thanks earned: 6,149
    People are saying a 650B will fit on a standard 26" Fox fork without grinding. I looked at my Yeti set-up with the TALAS and I'm not seeing an extra 1.5" with tire clearance. But it's been done, so
  11. #8
    . katonk's Avatar
    Oct 2007
    Thanks
    1,510
    Thanks earned: 1,384
    Quote Originally Posted by tkblazer View Post
    That does read like it was written by a team of lawyers.
    Will a 650b wheel fit in a 26 inch fork? If so, do you have to actually modify it to fit?
  12. #9
    Jan 2005
    From
    SoCal
    Thanks
    156
    Thanks earned: 63
    Quote Originally Posted by PacMan View Post
    Wouldn't it be 3/4" either side of the axle ?
  13. post thanked by:
    Chewyeti (01-07-2008)
  14. #10
    STR Veteran el_d00der1n0's Avatar
    Sep 2007
    Thanks
    3,242
    Thanks earned: 3,918
    wouldn't that be .75?
    evel knievel beat me to it. i thought he was dead.
  15. post thanked by:
    Evel Knievel (01-07-2008)
  16. #11
    ah buh bye now
    Jul 2007
    From
    Boston
    Thanks
    1,238
    Thanks earned: 2,098
    I heard 26" inch wheels fit fine with the current Fox forks, so there is in fact no need to even try to fit 650b's in there.
    Gone for good. PEACE.
  17. post thanked by:
    2wheel_lee (01-07-2008), BrewMaster (01-07-2008), el_d00der1n0 (01-07-2008), katonk (01-07-2008)
  18. #12
    Thirsty BrewMaster's Avatar
    Jul 2007
    From
    Foster City, CA
    Thanks
    10,894
    Thanks earned: 8,239
    The latest MBA article on 650b says they fit most standard 26er forks. Still, using a part beyond what it was designed for isn't the best idea IMO.
    “Very few are meant for a life of notoriety, yet all of us are meant for a life of significance."
    Erwin McManus, Wide Awake
  19.    Sponsored Links
  1. A warning to all Fully Loop trail users!!!!
    By Steven Jackson in forum General Discussion
    Last Post: 08-04-2008, 07:57 AM
  2. Thunderstorm Warning (2:25pm to 3:55pm)
    By CeeDubb in forum General Discussion
    Last Post: 09-02-2007, 02:09 PM
  3. Flash Flood Warning on TV
    By LBmtb in forum General Discussion
    Last Post: 09-02-2007, 07:41 AM
  4. Warning... Arroy Trabuco!!! and Introduction
    By commplex in forum Ride Reports
    Last Post: 09-01-2007, 03:12 PM
  5. Large 03 Enduro Pro (warning: long rambling)
    By tbowren in forum The Market Place
    Last Post: 08-29-2007, 02:33 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
